20 Most Recent
Sony Ericsson Z800i Cellular Phone Questions & Answers
Sony Ercisson 1GB memory card not reading
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
I want to unlock my sony ericsson z800 how do i do
You can unlock it by using the Unlocking code that is best One..In the site http://www.mobileunlockguide.com/ you can get the Free Unlocking instructions for the Sony Ericssion T290i model Mobile.It will help you in unlocking process..
Housing of my sony ericsson z800i
I can give you instructions.But my sincere advice to you will be DONT TRY TO CHANGE IT BY YOURSELF or with the help of unauthorized service centres. It is a bit complicated process. You may loose some internal parts like bluetooth antenna, internal connections etc. We cannot recognize some parts like bluetooth antennaas you may think that it is some broken part of the housing :).Please give it to any authorized sony ericsson service centres.
Sony ericsson ck131not sccept sim card
What message are you getting on the screen when you turn the phone on? Is it recognising there is a sim card there but not letting you use it? The most common reason for this is often a 'Locked' handset. Most networks set the phones the sell to only work for their sim cards. Most specialist phone retailers can usually Unlock the handset for a small fee.
If it isn't recognising that there is a card there it will either be a faulty sim card or a faulty phone.
My sony ericsson t700 internet settings does't install why
This phone was first released in 2008 and Sony's support for mobile phones by an agent is discontinued. In short, calling Sony for support won't help. The T700's technology was GMS/HSPA. T-Mobile and AT & T are carriers which access such. Whether either would assist you with setting up network connections is unknown to me. It sounds like your query involves the basic setup. I would review that in relation to the feature you are attempting to access and then query your carrier. But that route may offer no joy. The user manual has a troubleshooting section Here is the user manual for the T700 but there is a real question of your access to software updates for a 2008 release phone. I have no idea of the veracity of the service that claims to offer repairs or unlocking for this phone. This looks like an exercise in frustration. Sorry.
https://www.manualslib.com/manual/322716/Sony-Ericsson-T700.html?page=65#manual
Block stolen phone using imei
Unless you had an app like LookOut or Prey (highly recommend both) it is highly unlikely. Try talking to your service provider and see if they can track the GPS, otherwise you are SOL.
Unlocking code for sony ericsson S001 for free
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Hard reset my sony ericsson cell phone
Open the Emergency call keyboard.
Enter this code: *#*#7378423#*#*
From the Service Menu select: "Customization Settings".
Select "Reset customization" and "Reset customization and reboot".
The Android system will erase all personal information and will reboot the phone to the original factory settings.
