20 Most Recent
Sony Ericsson J230i Cellular Phone Questions & Answers
Forget reset password
There is four simple step to format . just follow it.
remember if ur phone memory have important data so u should be aware that i will erase ur data.but there is no other methods so..
1-
Power down your device. Before you begin the reset procedure, you will need to completely power your device off. If it is frozen, you can pull the battery out to turn it off.
2-
Press and hold the recovery buttons. The buttons vary from device to device, so you may need to look up the instructions for your particular phone. You will need to press and hold the buttons for a few seconds. Some of the more common button combinations include:
- Volume Up + Home + Power
- Volume Down + Power
- Home + Power
- If none of the above work, do a web search for your phone's model plus "recovery mode".
- 3-
- Select Factory Reset. Once the recovery menu opens, you can navigate the menu with the volume buttons. You may need to open the Recovery menu to find the Factory Reset mode. Use the Power button, some models use the camera button, to select your menu options.
- You will be asked to confirm the factory reset.
- 4--
Wait for the restore process to compete. After your phone resets, it will be set back to factory defaults and will be like it just came out of the box.
Instalation GPRS
GPRS NOT ACTIVATING,SO HOW TO INSTALLING GPRS SETTINGS,NOT SAVING SETTING,
Pls help me for manual settings for Vodafone Gprs for my J230 mobile.
Cannot receive sms
HalloHave you checked the in-box? If it is full you can't put more inTry delete. some messages, if no sms can come in then you will have to check . the settings.kollagunn
How do i decode my
Sony Ericsson J102I and Sony ericsson ELM are same phone,You can unlock it using the unlock code,you can get the Unlock code at here
Onlinegsmunlock.com and Unlock it.
No msg going
your message service centre number will not be correct enter it correctly as follows
you will get the number from service provider
Phone is switched off, am
first you check whether the battery is working properly or not if there is problem with battery then you replace it with new one.
when u switch on your cell if it gives sound but not showing any display means it is the problem with the display.
if battery is in working condition and it is not starting means it is the problem with it's IC chip
