20 Most Recent
Sony Ericsson J220a Cellular Phone Questions & Answers
Enter unlock code
Hi is your sony ericsson J220A mobile is locked to network ..Then have a look at sites like
Theunlockspot.com here they render code to remove the network lock ...You can purchase this code and unlock your mobile ....
How to unlock the SONY
Hi,you can try unlock codes from your provider or can get it from online providers..once i got unlock code for your mobile from
classicunlocking and got my mobile unlocked..you can too getting codes from them and get your mobile unlocked...
Pls. send me the unlocking
Sorry i can't provide the Unlock code,no one give it.You can get from Online sites,Because Network Unlock code is gather from Network Database!!! It based on your Brand,Model,IMEI,Network LOCK and Country.so get from online sites,....also please specify the Network and Country it locked,You can get the Unlock code at here
Theunlockarena.com
I have a sony ericsson J10i2, I bought it off
Hello and Welcome to FixYa!
Inactive SIM message may arise due to more than one issues. First things first check the hardware of your phone, to do this Put out the SIM card and check what happens. If it shows insert SIM card, its normal. If it shows the same inactive message then hardware malfunctioning.
Ok if the hardware is ok, then its simple. Inactive SIM means that your SIM card is not being able to register your Network carrier. The Phone with a red-line means SIM card registration failed. Although the signal radar works. This may be due to 2 issue; either there is a issue at the Service provider End, to check this call the service providers from other cell or land-line and check the status of your connection against this SIM Card No. If they say everything is ok. Then Its confirmed that your Phone is Network locked (Can only be used for one specific network) In this case coordinate with the seller.
I hope you will have a clearer picture now.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
In the puk code for
the PUK could be asked from your carrier, such as Vodafone, Hutchinson, etc...
the handset will automatically ask for PUK code, if you have entered wrong PIN codes for three times
How do I transfer pictures from phone to my
sir you have to install the sony ericsson pc suite to the computer.then connect the data cable from cellphone to the computer and then you transfer the files.................
J220a sony ericson
IT CAN BE ONLY UNLOCK BY CELLPHONE TECHNICIAN USING A SOFTWARE SE TOOLS
Battery
i have nokia 7610 but gosh mya battery easily get drained, it tooks 3 hrs of use ,im using the correct battery -5c something like that,, pls help me find the solution
Help
you didnt completed your question what code it asks?
is it pin code or security code or unlock code
1)if it is pin code means it is your sim card s code this will get blocked after three attempts then you must contact your network operator s customer care to ask the puk code and then if you enter puk code that s all it will work...
2)if it is security code or unlock code then you try the default codes 12345 & 0000 respectively... or if not insert howmuch ever possible zeros(0)...
if there is no improvement means you just ask the handset owner who has set the code...
if it is not possible then take your cell to technician for flashing(means installing near software)
technician will be using one special DKU series cable which connects the pc & while purchasing it they will provide one software which will be having the option like to reset the code,flashing etc....
so i suggest you to take your cell to technician
