20 Most Recent
VK Mobile VK2020 Cellular Phone Questions & Answers
My behold screen wont work
You need to replace the 'digitizer' on your phone. You can find them on ebay
for around $10 and do it yourself. Or most cell stores will charge $30-$40 on average.
CommCentral
My t-mobile behold touch screen stopped working
my phone did the same thing...if you are out of warranty you can fix it yourself, you just need to get a new "touch screen digitizer." you can order them on ebay for around 10 dollars, they usually even come with a little screw driver and seperator, if you are comfortable taking apart the phone its pretty easy and strait foward. 6 really small phillips screws on the back then it opens up, lift gently on the center of the latch on the back the phone to get to the last 2 screws, it'll slide down. The guts to the phone is held in by small clips all over so be carefull or you'll break them. Just pry them back carefully. As for the digitizer screen it's basically glued on the front. The only reason you gotta take the phone apart is for the small flat data cable attached from the screen to the inside. Gently lift up the black piece of plastic and pull the old cable out the slot, remove the screen(glued in) and work backwards from here......... it's not too bad...
Keypad lock
to unlock, the default code is the last four of your phone number usually.
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
Yesterday
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM •
Cell Phones
Answered
2 days ago
