20 Most Recent Frigidaire FRT15G4B Top Freezer Refrigerator Questions & Answers
Good Morning Friend,
I understand you are looking for the cubic footage on your Frigidaire refrigerator, model# FRT15GB4. Per the specifications manual, your appliance is 14.8 cubic feet. I ask that you please follow up with a comment on the post, at your convenience, to advise of further questions. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jun 19, 2014
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Frigidaire... | Answered on Sep 16, 2011
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
Frigidaire... | Answered on Mar 07, 2011
First question I would have is if the outlet is a dedicated line with nothing else on it. Also, does the GFCI in question have a high enough amperage rating for the refridgerator. Next, make sure the circuit breaker is not also a GFCI circuit breaker. You cannot have a redundant GFCI in the same circuit, one or the other. It can be very tricky to put an appliance like that on a GFCI circuit due to its compressor motor. Motors have a large amperage draw on them when they start so, if your fridge runs at around 10 amps, it can take three times as much to start (30 amps) which would trip a 20 amp GFCI.
Frigidaire... | Answered on Nov 29, 2010
Most refrigerant leaks happen inside the freezer behind the back panel and in the evaporator coil. If you would like me to help you resolve this please let me know, Thanks, Sea Breeze
Frigidaire... | Answered on May 14, 2010
If you are blowing hot or room temperature air the problem is related to the compressor or heart of the unit. It is either not running or running and not pumping.
#1 the compressor is in the back of the refrigerator near the floor, it is about the size of a bowling ball and black in color. If you hear it humming while running then a single click every few minutes it is not starting. The problem is most likely the relay part number 218721120. The part will run about $26.00
#2 the compressor is running and not pumping, if this is the case the repair cost will usually run about $500.00
Frigidaire... | Answered on Apr 18, 2010
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Frigidaire... | Answered on Oct 10, 2009
In spite of keeping the temperature regulator 'Low' mode if it freezes up so fast, that means there is a problem in the freez pipe from where the cool air is coming into the freezer. Please check on that. Make sure, that u defrost it once in a week.
thanks,
saumya.
Frigidaire... | Answered on Jul 13, 2009
Some compressors are designed to be externally cooled some are not.
They have to process the refrigerant to certain pressures to operate correctly.
The specific condenser and expansion device do the rest.
By cooling a compressor artificially you make it work harder to do its' job.
Cooler is not always better.
Frigidaire... | Answered on Feb 22, 2009
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Frigidaire... | Answered on Feb 09, 2009
no what rpobebly happened is that your freezer fillefd up with humidity and now its shorting out and tripping the breaker. make sure that theres no ice in the freezer also you should not really have it plugged intoi a gfi outlet.if its in the garage near the breaker panel i would add a dedicatefd outlet for the freezer from the electrical box.
Frigidaire... | Answered on Jan 21, 2009
the clold cointrol wil cost around 50 dollars and theyt are not that hard to replace. take the model number and make to the parts house and they will be able to set you up with a new one. good luck
it could be your cold control stuck turn it on and tap it a few times
Frigidaire... | Answered on Jan 12, 2008
it sounds as though you have a clogged drain.you will need to defrost for 24hrs for good results.also you could have a seal problem near your airflow vent in ref.compartment in this case you would need to contact your local tech.
Frigidaire... | Answered on Dec 21, 2007
Frigidaire FRT15G4B Top Freezer Refrigerator Logo
31 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
refrigerator tripping ground fault
  • Refrigerators
