20 Most Recent Honeywell ER150B Air Conditioner Questions & Answers
2answers
Central air does not kick in.
It sounds like you have a bad capacitor to the compressor. The humming noise is the compressor not starting up but is trying. It is either the capacitor or the compressor form your description. If you had a lightning storm or power surge about the time this happened it is most likely a bad capacitor. You can have the capacitor tested to see. Disconnect power before working on unit!
9/6/2017 12:05:57 AM • Honeywell ER150B... • Answered on Sep 06, 2017
How do I unlock a honeywell
This is because your home is more than 2 degress colder than you thermostat setting. Your heater is probaly broken.
12/12/2014 5:15:35 PM • Honeywell ER150B... • Answered on Dec 12, 2014
2answers
What does it mean when my thermostat says hold -ac
does it have hold then a number?? hold means that you want to hold that temp
10/31/2014 9:39:37 PM • Honeywell ER150B... • Answered on Oct 31, 2014
2answers
Ac won't turn on it just clicks.
Hitachi DC Inverter Scroll Compressor have a startup problem. when i start the unit the compressor start a voice of " Tak, Tak , Tak rasie and after 30 Second the compressor trip, after few minutes the compressor again try to start and again Tak, Tak, raise and compressor trip. please somebody help me about this issue.
8/25/2014 9:09:04 PM • Honeywell ER150B... • Answered on Aug 25, 2014
I turned it down to 65 F to cool off house but
your compressor is not running for some reason setting thermotat to 65 does not make this unit cool any faster
7/6/2014 4:00:42 AM • Honeywell ER150B... • Answered on Jul 06, 2014
My duted air conditioning started blowing hot air
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
5/14/2014 1:05:39 AM • Honeywell ER150B... • Answered on May 14, 2014
Honeywell 97-4118/5-89
probably low on freon. i assume compressor is running?
1/25/2014 2:01:13 AM • Honeywell ER150B... • Answered on Jan 25, 2014
I have a Haier air/heating unit. The heat has stopped working.
Keep heating mode and temp setting at minimum 3 to 4 degree C* between room and required temp.If still not working, replace the heating sensor.Tnx
11/16/2013 12:00:04 PM • Honeywell ER150B... • Answered on Nov 16, 2013
How to fix this no heat problem
Check fan/limit control on older unit. newer unit check limit switch
11/13/2013 11:25:49 PM • Honeywell ER150B... • Answered on Nov 13, 2013
ON THE UNIT OUTSIDE I
Hi, if the button has tripped, this is normally due to a problem, as this is a safety. But it may also be that the button its self is faulty if the unit is running properly. You must make sure you have no other problems going on such as high head pressure in system by washing out the condenser coil, checking motors, looking over the electric connections for any signs of burned spots ect. You can just simply take the wiring at the reset button and bypass it to run, but if you have a problem you are unaware of, this will cause a problem. What I would do is write down your model and serial numbers, kill power to unit...., remove this reset and take it to any retail appliance parts house to get one that will take its place. Just about any kind will work if the voltage is correct and amperage, even if it will not fit the hole or not. You can mount it any where inside out of the weather, just make sure you draw a diagram when removing it so you will remember how it goes back. If the new one trips right away, you indeed have a problem in the unit and will need to find it. You can do this by process of elimination to see when it holds when you disconnect a componant. Please rate me on my help to you, and I will help you until the problem is solved.Shastalaker7A/C, & Heating Contractor
8/28/2011 6:59:57 PM • Honeywell ER150B... • Answered on Aug 28, 2011
Loud rattling sound coming from the "fan" main
Sounds like you have a problem with the indoor blower inside that cab. hope this helps.
8/13/2011 1:28:14 PM • Honeywell ER150B... • Answered on Aug 13, 2011
Is there a manual to
Myself download and checked. Go with:
www.honeywellparts.com/honeywell-er150b-parts.html
Helpful?
1/6/2011 4:07:33 PM • Honeywell ER150B... • Answered on Jan 06, 2011
Who should i call to
i would ask around to friends and family first to see if they have had a good experience with someone. Usually the one that advertises the most is not the honest company..
8/20/2010 1:34:07 AM • Honeywell ER150B... • Answered on Aug 20, 2010
The temperature in my apartment
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
8/19/2010 7:13:13 PM • Honeywell ER150B... • Answered on Aug 19, 2010
I have never used central ac before - how do I set
You have it right. The number you set is the temperature it will give you.
Higher number, Warmer. Lower number, cooler.
Good Luck,
Wayne
8/14/2010 1:28:44 PM • Honeywell ER150B... • Answered on Aug 14, 2010
I recently bought a home with a honeywell air
you should call honeywell , give them model and serial number and they should be able to help you . they would help you with tour manual .
8/11/2010 5:39:51 PM • Honeywell ER150B... • Answered on Aug 11, 2010
My airconditioner will not turn on.
Here is a tip about trouble shooting your air conditioner...
heatman101
7/12/2010 2:30:10 AM • Honeywell ER150B... • Answered on Jul 12, 2010
Honeywell ER150B Air Conditioner Logo
Popular Tags
59 questions posted
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Heating & Cooling
Most Popular Question
never used central ac before set
  • Heating & Cooling
