20 Most Recent
Frigidaire GLRS267ZA Side by Side Refrigerator Questions & Answers
The ice dispense auger will not turn
The reason these tips are not helpful is this: My power was out 9 hours from 4:15 p.m. until 1:00 a.m. this morning. This auger in my Frigidaire side-by-side froze up in the motor area once before. Took a service tech to remove it and put it under hot water which fixed it several years ago with power off 9 hours then.
I took the ice bucket out, dumped the cubes, and cleaned it well. I cannot leave the freezer door open!! I'm going to try pushing the cube release, but it usually just hums.
I would use my blow dryer, but the cord is too short to reach an outlet and not sure what extension cord to use to match the AWG of the dryer cord.
It cost me $85 to have that tech here for 10 minutes and I'd like to fix this myself, free.
Any ideas on how to manage my blower drying cord/extension cord issues?
Thanks,
Bettyj
Our fan doesn't appear to
Condenser fan motor that isn't working will cause center post to get hot. Replace condenser fan motor
HOW TO CHECK COMPRESSOR
Good Morning Friend,
I understand you want to know how to check the compressor on your Frigidaire refrigerator, model# GLRS267ZA. The best way that you can check the compressor, is to make sure that you hear it running. Anything further, is not typically a do it yourself job. I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is going on with the compressor. Hope this is helpful.
-Best Regards-
WP
Model GLRS267ZA side by side
the filter should be relaced at least 2 times a year, a lot of times filters are sold at Lowe's, Home Depot, or other hardware stores. Also i have included the part# which could be copied and pasted and searched using a google search (shopping tab on google search)
part# 240396401
Food is frozen in refrigerator
I'm sorry that the side by side refrigerator is freezing everything. Frigidaire Refrigerators have either a mechanical defrost timer
or an ADC (Adaptive Defrost Control) to control the defrost rate. Based on the information
you have provided, it appears that the timer is failed in your case. If your
refrigerator has a mechanical timer, set the cold control to the coldest
setting and then advance the defrost timer. You can manually advance the timer
with a screwdriver. Insert the screwdriver into the advancement pinion and turn
clockwise a 1/4 to 3/8's of a turn.
Also I suggest that you leave the refrigerator unplugged and doors opened for more than 5 hours to check whether it is an issue with the defrost settled already.
Thanks for understanding. Please let me know if you require any clarifications.
FREEZER IS NOT FREEZING FOOD
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
