20 Most Recent
Frigidaire FRT18B4A Top Freezer Refrigerator Questions & Answers
Fan blows out a smell from underneath fridge could it be leaking gas.
call the repairman back and say forget it ,on the motor youll see a flat pan ,like a cookie sheet on top ,the excess water from the freezer drains into a tube and into that pan as the motor gets hot it evaporates the water,just clean the pan,shut down fridge,unplug and let motor cool,clean the pan and tell hubby not to waste good beer lol
Freezer part is cooling.refrigerator is not
Good Morning ehsanulhaq, thank you for your inquiry!
Being that you have a top
mount, the vent in the freezer is what circulates air down to the Fresh Food
section, making it cool. Here are a few simple troubleshooting tips that may
help you resolve this issue:
First
check clearances around your refrigerator. There must be adequate space around
a refrigerator with a static condenser so that air can circulate properly.
Proper clearances include 1" at the back and 3" on top of the refrigerator.
Examine
your doors. If the doors have been opened too often or for too long, this may
have allowed warm air to enter the refrigerator. Make sure to shut the door
completely and be sure not to keep the door open for too long. Even leaving a
door slightly open can allow too much warm air intake. Make sure refrigerator
is level and keep food and containers from blocking the door closing.
Check
the door seal. You do this by placing a dollar bill between the body of the
refrigerator or freezer and close the door. The dollar bill should stay in
place and pull out with a small amount of resistance. If the dollar bill falls
out when placed between the gasket and cabinet, double check to see if the door
is being blocked by anything that may be stopping it from closing. If nothing
is stopping the door from closing then replace the gasket.
Check
to see if the condenser is dirty. A dirty condenser cannot release heat
efficiently into the surrounding air. Cleaning the condenser may be necessary,
more if you have animals in the house. If you have condenser coils, they should
be wiped occasionally with a damp cloth to remove accumulated dust. The
condenser coils should be wiped occasionally with a damp cloth to remove
accumulated dust.
Check
for any obstructions to the vent to ensure proper air flow. If the vent is
blocked, the air in the refrigerator will not get cool.
I recommend to double check the
freezer control. If the freezer control is set too warm, set freezer control to
a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I
would strongly suggest contacting an authorized service technician who would be
better able to assist you in the diagnosis and repair of your unit. You can
often locate an experienced technician in your area by going to the
manufacturer website.
10/10/2013 11:32:05 AM •
Frigidaire...
Answered
on Oct 10, 2013
Samsung fridge freezer model number
Hi just wondering if you figured out the problem with your Samsung fridge yet.
It is definately a problem with the defrost part of the fridge. After approximately 4 to 10 hours dependent on many different factors it enters into defrost mode to get rid of any excess ice in both the fridge and the freezer. During the defrost stage the compressor will not run. If any fault occurs during the defrost stage the fridge will not restart unless you turn it off and back on again which restes the pcb and takes it out of defrost mode and the timer starts again.
Please let me know how you went with it.
Defrost cycle making noise a humming noise every
Does this noise come from behind the frig if so remove rear panel and touch the top of compressor, if its real hot (just be careful can burn the heck out of your fingers) then you will need to test the compressor. Let me know.If the noise is coming from the inside of frig at the top then your defrost timer is a noisy one and you should replace it
