20 Most Recent
Frigidaire FRT18G4A Top Freezer Refrigerator Questions & Answers
Transported a fridge on its side, waited 24hrs, plugged in.
Transporting frig on side probably damaged the compressor due to the oil inside draining from bottom. Do you know if the bulbs were working before you purchased? If they were you may have damaged the door switch, easy fix, just replace. Compressor replacement should be left to a pro. Probably looking at a couple hundred. One other thought is you might have caused a gas leak during transporting, another job for a pro.
Fridgidaire top freezer fridge
Hi thanks for your question. the problem with your fridgethethat the drain tube is clogged up. the drain goes down between the walls, down to the drip tray, at the bottom by the drain pan. to repair. . the fridge has to be turned off for at least 24 hrs. to thaw the ice in the drain tube. then using a small plasti, push small hose up the drain tube,the bottom at the drain tray. blow up the tube to clear. thanks the appliance doc. please rate my answer.thanks.
My Westinghouse RS662V fridge is
Yes you need to adjust the thermostst located inside the fridge compartment to change the temp. setting of the fridge.
Regards.
PLZ. dont forget to rate my suggestion.
Will the freezer work after
yes it should be fine how ever you may need to run the unti for about fifteen minutes then shut it off four half hour or so then start it back up you should not have nay problems with it./
Not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Coldheatman101
