20 Most Recent
Hotpoint HDA2000G Built-in Dishwasher Questions & Answers
DIrty Dishes
try running it through empty with some cleaner in it check all the in side for anything clogging it and then if you can put some hot water in it to loosen any grese
7/10/2014 1:15:13 PM •
Hotpoint...
Answered
on Jul 10, 2014
I have tried everydishwasher detergent that there
Run hot water in the sink so that it is hot when it enters the washer. This is in case your heating element is not heating well enough. I realise this posting is not a solution but rather a possible clarification on previous advice.
10/9/2010 3:09:16 PM •
Hotpoint...
Answered
on Oct 09, 2010
Just moved into an apt.
Your are right. There is a Barrier heater element to heat the water inlet part#
AP2038346 to warm water prior to enter the dishwasher. The part is around $14. Maybe they don't want to fix it so it is a way to tell you to get around. Cheers.
8/12/2010 1:18:56 PM •
Hotpoint...
Answered
on Aug 12, 2010
Have a hotpoint aquarius dishwasher
Won't work powers up
Red light comes on with salt
2 nd red light come on showing X
What is the X?
Please
Here's what you can do to address this issue:
- Check the Salt Level: Ensure that the salt reservoir is filled with dishwasher salt. The dishwasher needs salt to soften the water and improve the cleaning performance. If the salt level is low or empty, refill the reservoir with dishwasher salt.
- Check the Salt Dispenser Cap: Make sure that the salt dispenser cap is securely closed. If it's not closed properly, it can cause the "X" symbol to appear on the display.
- Reset the Dishwasher: Try resetting the dishwasher by turning it off at the mains power supply for a few minutes, then turning it back on. This can sometimes clear error codes and restore normal operation.
- Check for Blockages: Ensure that the salt dispenser and its inlet are free from any blockages or obstructions that could prevent salt from dissolving properly.
- Consult the Manual: If the issue persists, refer to the dishwasher's user manual for troubleshooting steps specific to your model. The manual may provide additional information about error codes and how to resolve them.
If none of these steps resolve the issue and the "X" symbol continues to appear on the display, it may indicate a more significant problem with the dishwasher that requires professional diagnosis and repair. In such cases, contacting Hotpoint customer service or a qualified appliance technician for assistance is recommended.
2/20/2024 10:45:42 PM •
Hotpoint...
Answered
on Feb 20, 2024
