20 Most Recent Frigidaire FRS23W3A Side by Side Refrigerator Questions & Answers
Freezer side is making an extremely loud humming sound. Ice maker is working fine. No ice buildup anywhere in the freezer that we can see. Loud humming goes on for a few minutes each hour.
Hey Joanne, I appreciate your inquiry!
Based off my understanding the freezer side of your Frigidaire refrigerator is making a loud humming noise. The humming sound could be coming from your compressor. If the sound is a new development it may be a possible issue with the fan pushing further against the wall. You may need to seek help from a professional technician for proper diagnosis and repair. This will help you from purchasing any unnecessary parts. Hope this information is helpful to you. -Matt
1/2/2016 2:52:51 PM • Frigidaire... • Answered on Jan 02, 2016
215846602 215267800
Hello Jennifer - Often when the temperature is too cold, it is because the temperature control is set too cold/high or the damper door is not closing. Turn the control to a warmer setting and allow several hours for the temperature to stabilize. If the unit stabilized within 24 hours and the issue persists, then more than likely the control is not telling the damper when to close and/or the unit might possibly have a faulty thermistor or temperature control. I would personally contact a professional to accurately diagnose the unit to determine the root cause to reduce the risk of unnecessary parts.
7/3/2013 6:04:48 PM • Frigidaire... • Answered on Jul 03, 2013
Liner is warm
usually normal, but make sure the fan in back by the compressor in on
10/11/2012 9:23:30 PM • Frigidaire... • Answered on Oct 11, 2012
Ice maker not working
If your ice maker has stopped producing ice completely, try checking the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
10/11/2012 1:39:38 PM • Frigidaire... • Answered on Oct 11, 2012
2answers
Water freezes in refrigerator
Either your damper motor control is bad.....or the Cold control is bad....
10/4/2012 7:00:02 PM • Frigidaire... • Answered on Oct 04, 2012
Compressor of the refrigerator keeps turning on and off
You have to troubleshoot the control devices such as thermostat. You need a voltmeter to test the control circuitry
5/14/2012 4:45:08 PM • Frigidaire... • Answered on May 14, 2012
Hi i have a problem with my side by side freezing
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/14/2011 7:23:59 PM • Frigidaire... • Answered on Aug 14, 2011
2answers
Location of defrost timmer
The defrost timer on your model is inside the fresh food compartment and behind the controls. Just above the top shelf. Click Here=> FRS23W3A Control Panel
Location 23 in that photo is the timer part Number=> 215846602 Defrost Timer
Some model's have the=> 240375803 Adaptive Defrost Control
Either way should you have questions I will be here to help you. Please rate this solution, Thanks, Sea Breeze
6/21/2011 2:44:09 AM • Frigidaire... • Answered on Jun 21, 2011
0answers
Everything on the upper shelves in the fridge part
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
9/5/2010 1:44:31 AM • Frigidaire... • Answered on Sep 05, 2010
Fridge just wont turn on
try and replace the overload relay and start ptc on the compressor. if the compressor starts then you need to check the current draw on the compressor with a clamp meter if you have one.the current draw should be between 1.2 to 1.6 amps.if it is not within that range then replace the compressor
8/31/2010 10:12:21 PM • Frigidaire... • Answered on Aug 31, 2010
I need to remove doors to get in kitchen, how do
If you are asking that question, sorry you're not qualified for that job. Seek professional help, or you can screw up your refrigerator big time (read - broken tubing,wiring, misaligned gaskets, twisted hinges, not leveled doors, a few hundred $$$ in repairs).
11/26/2009 8:34:51 AM • Frigidaire... • Answered on Nov 26, 2009
Water just started tasting bad
suggest you go to appliancefactoryparts.com. At this site you can locate you model refrigerator and get an exploded view or your refrgerator and a manuel.
7/19/2009 5:08:43 PM • Frigidaire... • Answered on Jul 19, 2009
Frigidaire FRS23W3A Side by Side Refrigerator Logo
26 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
215846602 215267800
  • Refrigerators
