20 Most Recent Frigidaire PHSC239DSB Side by Side Refrigerator Questions & Answers
Sounds like the defrost timer isn't set to the correct time. You want it to operate in the middle of the night not during the day.
Frigidaire... | Answered on Jul 29, 2016
Search for "frigidaire power board" on youtube
Frigidaire... | Answered on Jul 16, 2016
Behind front grill below the doors, on the left in a box held in by one screw. There are two screws there. I unscrew the one pointing up so the metal bracket comes out with the box.
I have the same problem. Also no power to the water valves or the connection at the top hinge of the freezer door. Also, nothing at the wire going to the freezer light switch. The switch is good as is the bulb. Everything else seem to be working ok. Wondering where to check next.
Maybe not defrosting. Take out several baskets until you can get at the screws that hold the back panel on and remove it. Now you should be able to see the evaporator. And likely a lot of ice/heavy frost. In that case, use a blow dryer or heat gun - I used the latter since I had so much solid ice - and start melting the ice away. Before you melt the ice around the defrost thermostat which clamps to one of the evaporator tubes, disconnect its 2 wires and check for continuity. Should have continuity when it's that cold. Then check continuity for the heater element. Usually it's around 30 ohms. If you're lucky, the fault lies with one of those components.
If it's like my PHSC239DSB, it's behind the front grill, left side, in a box that will slide out once you take out a screw. If there are two screws, one going upward and one toward the back, take out the one going upward. It's a bit more difficult but you won't have the metal bracket hanging down and in the way. Should just slide out. If not, use a flashlight to see where it's hanging up. Mine comes out far enough to unplug all connectors and to take off the bracket holding the harnesses in.
The button lock switch along with the other switches on the door use one common return wire for power to the solenoids. The freezer door light switch will stop power to the buttons if it has failed.
Good Morning friend, thanks for your post!
From what you have described you unplugged your Frigidaire refrigerator to clean it and now it is not cooling. You could have a possible short within the control panel or wiring harness. I would recommend performing a reset on your refrigerator and you can do that by disconnecting the power for at least ten minutes.
If that does not jump start your compressor you may want to make sure it is not in demo mode or the control is locked you should be able to notice any error codes on the panel. If you need additional help I would recommend contacting a professional technician for proper diagnosis and repair. -Matt
Frigidaire... | Answered on Mar 13, 2015
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Frigidaire... | Answered on Aug 11, 2011
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, cuts power to the cooling system and sends power to the defrost heater. In newer models the timer advances only while the compressor or defrost cycle is running - an improvement for efficiency. As the timer continues to advance, power to the heating element is cut and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
window.google_render_ad();
The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multitester should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it is likely that it should be replaced.
* We have received two reports of cases in which only one pair of terminals shows continuity and when the timer is advanced, the same pair still shows continuity. For these isolated cases, this was reported to be the correct operation of the timer. At this time we have not been able verify this case. This may indicate a specific model or models that use a different wiring configuration than discussed in this article. Also, note that this article applies to mechanical defrost timer controls and not electronic or adaptive defrost controls.
plz do raet this post.
best regards by acmehowto.com
Frigidaire... | Answered on Sep 22, 2008
According to your model number a bypass plug wont work. Refer to owners manual. I dont think they make a bypass plug for your model.
Frigidaire... | Answered 20 hours ago
Frigidaire PHSC239DSB Side by Side Refrigerator Logo
18 questions posted
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Carmen Mikulic
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
water amp ice dispenser don 39 t work
  • Refrigerators
