20 Most Recent
Frigidaire (FEB30S7D) Oven Questions & Answers
Unlock the oven door frigidaire Electrolux
IT should time out eventually. I am not sure if there is a way to reset it but if you hold the control lock button for 3 seconds (If it is Locked) and wait it SHOULD time out. I hope this helps to some extent.
There is a terrible smell from the oven
I would need to be there to verify but if it is not an electrical odor then I would suspect a dead rodent, or if you have pets a mouse could have packed the space between the liner and the frame with pet food. I had one that had stored 20 pounds of dog food in there.
Eric
11/11/2012 10:40:55 PM •
Frigidaire...
Answered
on Nov 11, 2012
Fault code f95, what is it?
This is the explanation that Frigidaire gives. Press stop
key. Turn off power for 30 seconds then turn power on. If the door lock
motor never stops rotating, or if the F95 error comes back again, verify
wiring of the motor. if wiring is good, replace the EOC. If the problem
persists, replace the motor latch assembly.
How much clearance is required between the bottom
The installation manual does not specify.
(If you need a manual you can get one here:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man)
As an installer, without a manufacturer's specification, I would assume no specific clearance is required. Further, if you check the exploded parts diagram in the manual you will note that there is an insulating panel in the base of the oven. Evidently the oven has been designed to insulate the exterior panel from excess heating and does not require any minimum clearance at the base.
Once oven heats up F1
The F1 fault code on your Frigidaire oven means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also known as a clock or eoc
Oven coil burning hot on one side, popped and
It is probably the coil. If liquid or grease spilled on it, that would be a good bet. Coils can be easily replaced, and I would start there before calling a service man. Just make sure you unplug the appliance before replacing it, and then make sure that the new one is firmly plugged in before putting the plug back in. Don't use the damaged coil, it can (probably will) catch on fire if you do.
Hi...need a light cover for
Hi
Thanks for using FixYa. Model numbers can be made up of numbers (1005400, for example) or a combination of letters and numbers (FEB30SD). The model number will most likely appear on either a paper sticker or a metal plate. If you have the product manual, you can find the model number from that. Also see this picture, it will help you--
Your appliance's model number tag may look similar to this--
This will help you to find out the correct model number of your Range and then you can visit this link, enter the model number and order the parts.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
3 wires black white ground from box from oven red
the appliance is 220 volt and the box you are describing is 110 volt. You cannot connect to this box. You need a new 220 volt circuit ran from your main panel box to the appliance with a 220 volt 3 prong outlet box like an electric dryer uses or make the connections in a box without using the plug system
