20 Most Recent
Frigidaire FEB30S5D Electric Single Oven Questions & Answers
My friigedare oven is not working we checked the elemaents thay are ok
Hello Izhar, this is Z. I am happy to assist you!
I see that your question is listed under Frigidaire wall-oven (FEB30S5D). If both the broil and bake elements are not heating, I suggest resetting your wall-oven. This can be done by either unplugging it or flipping the household circuit breaker to the off position. I recommend waiting approximately ten minutes and then turn on your appliance. If this problem persists, then your wall-oven could possibly be experiencing a potential wring failure, or a communication problem with the EOC (Electronic Oven Control). It would be advisable to contact an experienced appliance repair tech to assist further.
My oven gives an error code of F30 and the door
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Bottom element of my drop in oven(range) is not
Most likely the temperature sensor is bad. This is a small pencil shaped rod in the top of the oven.
Well,
to ensure the temp sensor isn't bad, you can take an ohm meter to the contacts
of it and measure the resistance. It should be around 20 ohms. If it is
much greater or infinite, then its bad. To get to the contacts
you will need to unplug the oven, pull it away from the wall and remove
the rear panel. Then disconnect the wiring
and touch the probes
from the meter to the contacts on the sensor. You can order a new
sensor locally or from repairclinic.com. Let me know what you find.
Benjamin
Stove out of service for
just because the indicators light up does not mean that u have 220 volts avail to the burners and oven, the first thing to do here is test the cord and make the 4 wire conversion was done correctly and u do indeed have 220 at the stove, the controls run off 110 volts leg, the plug uses two110 volt legs of house current to give the 220 volts needed.
Fan is not turning
yes if you ave is set for fan forced...no if you have is set for non fan force....a lot of ovens have many setting depending what you are cooking....top oven/bottom oven or fan oven plus a combination.
Had a small fire in my oven while the cleaning
Your oven heats up to over 800 degrees when you self clean it. ONLY clean it when it's very dirty and when you do, you risk the power outage of many electronic parts, so try NOT to self clean it, if you can get away with it. Hope this answers your questions. Call me if I can help. Ella
Frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
