20 Most Recent
Yamaha YST-SW012 Subwoofer Questions & Answers
How do i make this woofer work with my polroid tv
OK, it looks from what I can tell you need a 1/4" stereo plug for the input to your speaker system. The output from the TV is either RCA jacks or maybe a 1/8" sub mini stereo jack. You can likely go to Radio Shack or an audio store and purchase a cable that has the 1/4" stereo plug on one end and a 1/8" sub mini stereo plug on the other. That cable would mute the TV internal speaker or if you do not want to mute the TV speakers you can get a cable with the 1/4" stereo plug on one end and the L and R audio, RCA (phono) plugs on the other. That would give you both. RCA plug and 1/4" plugs are pretty easy to install if can not find the correct cables. Good Luck. The Yamaha unit looks to be self powered so impedance matching or load on the TV audio amps should not be a problem.
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
