20 Most Recent
Phoenix Gold XS6600 Car Audio Amplifier Questions & Answers
Xs4300
i checked all around the internet for that am and its a discontinued product as far as I know. i have found some for sale on craigslist but within no time they were sold even on ebay. but the main sites dont have it cause it maybe discontinued
Sub Wiring
if you wire the subs in parallel you would achieve 2 ohms which would theritically double your rms, sadly this isn't the case what with wire resistance and such you might get around 270 rms still not that bad. to wire in parellel you run a positive off the amp to the positive on one sub then run a wire from the first subs negative to the second subs positive the run from the second subs negative to the amps negative and bam 2 ohms but be warned this will put more stress on your amp and cause it to heat up faster. peace bro and best of luck
My phoenix gold iron not heating up all blue lights flashing "need help please "
If your Phoenix Gold iron is not heating up and all the blue lights are flashing, it indicates a potential issue with the iron. Here are some troubleshooting steps you can try:
1. Check the power supply: Ensure that the iron is properly connected to a functioning power outlet. Make sure the power cord is securely plugged in and that there are no loose connections.
2. Allow the iron to cool down: If you have been using the iron continuously for an extended period, it may have reached its temperature limit and shut off for safety reasons. Let the iron cool down for a few minutes and then try turning it on again.
3. Clean the iron's soleplate: Over time, the soleplate can accumulate dirt, residue, or fabric fibers, which can affect the iron's heating performance. Make sure the iron is unplugged and cooled down before cleaning the soleplate. Use a damp cloth or sponge to gently wipe the soleplate and remove any debris. Avoid using abrasive materials that could scratch the surface.
4. Check the water tank: If your iron has a steam function, ensure that there is sufficient water in the tank. If the water level is low, refill the tank according to the manufacturer's instructions. A low water level can prevent the iron from heating properly.
5. Perform a reset: Some irons have a reset button or a combination of buttons that can be pressed to reset the device. Consult the user manual for your specific model to find out if it has a reset function and how to perform it.
6. Contact customer support: If the above steps do not resolve the issue, it is recommended to contact the manufacturer's customer support for further assistance. They can provide specific troubleshooting steps or advise on repairs or warranty options if necessary.
Always refer to the user manual provided with your Phoenix Gold iron for model-specific instructions and safety guidelines.
