20 Most Recent Cat5e Unshielded Twisted-Pair Patch Cable with Molded Boots (UTP) Cat. 5E - 1.5 ft., Yellow (325165) Questions & Answers
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
11/24/2008 8:10:07 AM • Cat5e Unshielded... • Answered on Nov 24, 2008
Cable stuck
Look at the above left. There should be a plastic lever (with a little nose to hold the plug in) reaching a few millimeters out of the front panel of your hub. Press it to the body of the plug and pull it out. If the lever is broken, use a small screwdriver, a needle or a paper-clip. hth, Karl
11/27/2014 7:27:04 AM • Cat5e Computers... • Answered on Nov 27, 2014
Lag switch
Hey, you are dealing with high frequency - what a strange idea is this? Do you have a 100Mb/s- or 1Gb/s-network? What do you want to achieve?
11/27/2014 7:24:04 AM • Cat5e Computers... • Answered on Nov 27, 2014
25m and no signal
Two equipments of the same type - two computers, two routers, two switches - should be connected with a crossover cable.
8/13/2013 12:41:47 AM • Cat5e Computers... • Answered on Aug 13, 2013
2answers
There is 4 pair cat5E
To use 8 wires cable for 100BaseTX connection only four wires are used, pin 1,2,3 and 6. You can find defective wires by using wirescope which can detect which wire has problems. If these two wires are not one of these I had mentioned according to standards 568A or B (it depends of the rest of the network) then you can use it if not then take care wher to put these bad wires but not on pins 1,2,3 or 6. Take care to document this. The best solution is to replace this bad cable with good one and do everything according to standard procedure.
3/10/2011 6:05:30 AM • Cat5e Computers... • Answered on Mar 10, 2011
I need to wire a network cable into a wall plate
I have tried this, and my suggestion is to go back and get the proper wall jack. How much are headaches worth to you? If they are worth more than the wall plate, just **** it up and get the correct one.
1/5/2010 7:40:19 PM • Cat5e Computers... • Answered on Jan 05, 2010
I AM BUILDING A NEW HOME AND WAS TOLD THAT CAT 5
I'd go with CAT-6, if your building a new home. While CAT-5 would probably be fine for the near future, CAT-6 has a much higher bandwidth rating, and would be able to pass more data at higher speeds, and would in effect, "future-proof" you home network.
The future is all about high-speed data transmissions, and as more and more things are getting connected to a person's home network (Blu-Ray players, etc.) you're going to be glad that you did...
Everything is getting "smart" these days, there are even internet enabled refrigerators; while not common-place today, who knows what the next 20- to 30-years will bring...
Do it now, or re-do it in the future. The price is a little higher, but thin kabout how much more it will cost you to have the CAT-5 ripped out to be replaced with CAT-6 (or whatever) down the road...
12/13/2009 11:00:06 PM • Cat5e Computers... • Answered on Dec 13, 2009
I want to extend my cat5 cable how would I do
They make some special spicer to extend your net work. But for the life of me I cannot thin of the name of them. I have plenty of them, If you want you can email me with an address and I will send you some.
[email protected]
Darren
10/10/2009 8:26:22 PM • Cat5e Computers... • Answered on Oct 10, 2009
4answers
Transfering data from one computer to another
I think there is no way to do that. You CAN do it, however, with a crossover cable. It looks the same as a regular cable, but it's not. With the crossover cable, just connect the two computers and give 'em two IP's in the same network. Then enable file sharing and it should work. Sorry, I can't go into much detail because I haven't done that in a looong time, but I think that's about it. Hope it helps.
9/12/2008 3:40:56 PM • Cat5e Computers... • Answered on Sep 12, 2008
Where can i get mastering machine learning Tips for Tackling Assignment
Here
The Ultimate Guide to Conquering Machine Learning ...
makexyz.com https://www.makexyz.com > the-ultimate-guide-to-conqu... Feb 19, 2024 - When diving into machine learning assignments, it's essential to adopt a systematic approach. Break down the task into manageable components, ...
7 Steps to Mastering Machine Learning with Python in 2022
KDnuggets https://www.kdnuggets.com > 2022/02 > 7-steps-masteri... Sep 30, 2022 - Step 1: Learn Programming for Machine Learning ... You need to have a working knowledge of programming before you dive into machine learning. Most ...
Machine Learning Assignment Help
Medium ยท Abnerassignmenthelp 1 month ago Our experts can assist you in tackling machine learning assignments effectively. Deep Learning Assignment Help: Our team of deep learning . ..
4/24/2024 8:11:03 PM • Computers &... • Answered 8 hours ago
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 24 hours ago
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered 2 days ago
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered 3 days ago
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered on Apr 21, 2024
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered on Apr 17, 2024
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered on Apr 16, 2024
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered on Apr 13, 2024
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered on Apr 13, 2024
Computers & Internet Logo
2 questions posted
Top Cat5e Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cat5e Computers & Internet
Most Popular Question
phone cat5e cabling wire wall plate
  • Computers & Internet
