20 Most Recent
Carrier Beverage-Air SMF58 Questions & Answers
Wiring a thermostat on a milk cooler has spade 1
A thermostat is a switch, not a load. The purpose of the thermostat is to stop the power when it's cool enough in the cooler. So when the thermostat senses a lack of heat, it opens the circuit, thus, turning off your unit. It really doesn't matter which wire you put where because the thermostat is going to disconnect them either way. Just as long as they're not on the same spade it's fine.
4/2/2010 4:49:06 PM •
Carrier...
Answered
on Apr 02, 2010
Carrier unit pro earth ultra
clean your condenser with air pressure to blow out the condenser or use spray bottle to wash down the condenser and fan blade wipe down and make sure all lint is removed from air flow passages!
1/16/2018 1:51:16 PM •
Carrier...
Answered
on Jan 16, 2018
Our -12F design freezer was
you have another leak it has to be found by an experienced person, usr nitrogen to pressurize the system to over 200 pounds pressure then check again, use squirt bottle with soapy water to find leak, if no leak to be found then the leak is where u are putting your service gauge manifold set on, the shreader vales are not setting!
1/16/2018 1:37:01 PM •
Carrier...
Answered
on Jan 16, 2018
I have a very old
Hello, Paulfreling -
I did not find a link to the manual for your Beverage-Air unit on the company web site:
https://beverage-air.com/parts-service/
(Parts & Service page, with links to manuals and videos at the bottom of the page)
I suggest you call Customer Service at Beverage-Air and talk with someone there who may be able to direct you or provide you with the right manual. See the Technical Services Department phone number at the bottom of this page:
https://beverage-air.com/customer-support/
1/14/2018 5:41:33 PM •
Carrier...
Answered
on Jan 14, 2018
ALARM AL-15 ON CARRIER REEFER
hola qtal como estas, tengo un problema con un reffer de carrier modelo thinline con motor resiprocante que me da alarma al 15 y para el equipo no baja ninguna llave solo protege
3/19/2015 12:59:19 PM •
Carrier...
Answered
on Mar 19, 2015
