20 Most Recent
Generic A13-MID 1.2GHz 512MB 4GB 7" Capacitive Touchscreen Tablet Android Questions & Answers
Want to choose english language
Select settings, on the apps page, scroll down to language etc. and hit, select the language you want, presumably English, then try the phone. or tablet. The machine will now be in English. If you then reset it will probably go back to the language in which you got the phone so do not do it!
Tablets locked forgot password
You'll need to do a factory reset:
1. With the device off, press and hold Volume
Up and Power.
2. Release the Power button
when you see the logo, but continue to hold Volume Up until
the recovery screen appears.
3. Use the Volume buttons to navigate the menu
and select wipe data / factory reset. Press Home to
choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however
anything on your SD card will still remain.
At this point you will need to start fresh as if you just
bought the device -- register with your email address, etc.
Turns won boot
i need the make and model have you left it a long time it could be the battery flat needs replacing or problem with switch more info would help thanks
Blocked by pattern
1.
Up and Power.
2.
Release the Power button when you see the logo, but continue
to hold Volume Up until the recovery screen appears.
3. Use
the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4.
Battery issues
Sounds like you have far too many apps installed all demanding cpu and network (wifi) work even if they aren't open . Have a purge and be ruthless! Get rid of every app you don't use. Try and stay in same room or near to router so it's wifi doesn't have to use high power to stay in contact with it. Reduce the screen brightness as much as you can. looks dull at first but you soon adjust and get used to it. Remember the usb keyboard is also getting it's power from the tablet battery and will use much more than the touch screen does.In my experience the batteries on these are quite small. There is enough space inside for a battery 3 times the capacity of the one fitted. You might want to consider getting the battery replaced with a higher capacity one,. There's videos on youtube how to do it, or you could ask a local computer repair shop for a price.
