20 Most Recent
True 598-TSSU608ADA SandwichSalad Unit 155 cuft Questions & Answers
I recently purchase a coffee shop and found that
fixya is a diy --repair information / question site fixya doesnt go out to locations for repair --need to look for a lic dependable company and or call back company and advise of same problem persists and can they send someone else to fix what they worked on correctly should have a guarantee for the work done --talk to neighboring shops and ask who they use
5/11/2017 11:49:40 AM •
True...
Answered
on May 11, 2017
How do I take the door off ?
Open the door to a 90 degree angle, you will see two screws 5/16" or 3/8" hex head (must remove cutting board as well). One screw at pivot point on bottom remove and lift off door.
10/29/2013 5:30:30 PM •
True...
Answered
on Oct 29, 2013
Unit will not cool to below 40 degrees
Proably has small freon leak and that will cause it not to cool well just like a car that is low on freon.
You might be able to add freon and it may last for awhile but you might want to pay a good service shop for a leak repair.
Usually the leak is a tiny tiny tiny pin hole in the evaporator.
Some times you can repair them but if the unit is over 7or 8 years old replacement is best.
1/20/2010 1:24:27 AM •
True...
Answered
on Jan 20, 2010
Compressor working, cooling coils hot, but unit won't cool below
When you say fully charged, did you weigh the refrigerant? These small systems cannot tolerate overcharging by even small amounts because it will result in overpressure on the suction side. If there's too much refrigerant you get hot coils and cool but not cold evaporator. I typically pump the refrigerant into a recovery tank and then weigh it back in to get exactly the amount on the mfg label.
12/12/2009 3:45:36 PM •
True...
Answered
on Dec 12, 2009
Hi fan not working and cooling grids are icing up.
First unplugged the unit and let it defrost complete ,after this connect it back in and see if the fan works because if the unit does not defrost by itself , the fan blades get stuck with the ice and won't turn, but if still the fan doesn't work take it out ,get the same one and replace it it's very easy , unscrew the pannel then the fan and the 2 wires , put the new one the same way.
8/11/2009 5:40:13 AM •
True...
Answered
on Aug 11, 2009
Thermostat wont shut off unit
These units are bad about that. you have to mount the cap sensor in the small tube that runs thourgh the evaporator for proper operation. laying on top of the coil does not let the thermostat sense properly.
5/10/2009 9:37:14 PM •
True...
Answered
on May 10, 2009
Not cooling
Possible loss of refrigerant charge from a leak in the evaporator area. The cooling coils on these unit are exposed to acidic moisture from products stored such as tomatoes, pickles and other high acid foods. Thes Evaporator coils are replaceable.
6/8/2008 11:02:41 PM •
True...
Answered
on Jun 08, 2008
True tbb-3g fridge, left hand door sags, creates an air gap at the bottom of the frame where it meets the cooler, door lifts about 1/4 of an inch on the post
If the left-hand door of your True TBB-3G fridge is sagging and creating an air gap at the bottom of the frame where it meets the cooler, here are some steps you can take to fix the issue:
- Check the door hinges: Inspect the hinges on the door and the frame of the fridge. Look for any damage or wear that may be causing the door to sag. If the hinges are damaged, they may need to be replaced.
- Adjust the door hinges: If the hinges are in good condition, try adjusting them to see if this resolves the issue. Use a wrench to loosen the screws that hold the hinges in place, and then adjust the hinges up or down as needed to align the door with the frame. Tighten the screws back in place when you are finished.
- Check the door gasket: If the door gasket is worn or damaged, it may not be sealing properly and causing air gaps. Check the gasket for any damage or signs of wear, and replace it if necessary.
- Check the door closer: The door closer on the left-hand side may be damaged or worn, causing the door to sag. Inspect the closer and look for any signs of damage. If it is damaged, it may need to be replaced.
If none of these steps resolves the issue, you may need to contact a professional repair service to help diagnose and fix the problem.
2/28/2023 5:20:05 AM •
True...
Answered
on Feb 28, 2023
One month old True T-23 not cooling to set temperature. Display is unlocked and set temp is 36 degrees but fridge is continually at 57 degrees
It's possible that the issue may be with the thermostat or the compressor. If the thermostat is not working properly, it may not be regulating the temperature correctly. Similarly, if the compressor is not working properly, it may not be able to cool the fridge down to the desired temperature. It's best to have a professional take a look and diagnose the issue. Another possible cause is the refrigerant levels, if the refrigerant is low this can cause the compressor not being able to cool the fridge properly and will need to be refilled by a professional.
1/29/2023 11:03:02 AM •
True...
Answered
on Jan 29, 2023
Why does our Commercial True 3 door Freezer keeps tripping breaker?
The freezer door being open all night cause the compressor to run all night continuously trying to cool the unit down. This caused an increase in resistance and tripped the breaker. It may stabilise, but it may need a service call to fix the issue.
It may also be a lazy breaker and it is the breaker that needs swapping out. you can normally compare them against adjacent breaker, a lazy one feels soft and doesn't snap of Off when you move is slowly to the Off position. They also feel different when switching to On.
I have spent a 50 year career in catering and hospitality fighting fridges and freezers, electrics and plumbing. Now retired :>) Get this fixed by Easter because in my experience, it will break down on Saturday at 8:00pm!
4/7/2022 11:28:31 PM •
True...
Answered
on Apr 07, 2022
