20 Most Recent Nitro BMW-482 Car Audio Amplifier Questions & Answers
a hack wired it. the fuses protect your wiring which i suspect is too small for the amp load they are carrying.
Nitro BMW-482... | Answered on Aug 11, 2017
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Dou .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-comes-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Nitro BMW-482... | Answered on Dec 18, 2014
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty D .A thumbs up would be greatly appreciated if this answer is helpful to you. red-light-comes-while-lv2kkrmxrai4iihdvw4m3np2-2-0_0.jpg http://www.nitrobmw.com/
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. makes-nitro-1200-watt-amp-go-protect-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Definitely is worth .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-1200-watt-amp-working-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
If the amp is in protect mode, then there may be a speaker wire that is shorting out or you may have a bad speaker...you can test this by completely unhooking the speakers on the amplifier and then turning the amplifier on...if it comes out of protect mode then you will need to find out which speaker is bad...if the amplifier does not come out of protect mode when you turn it back on then there is a problem inside the amplifier and you will need to take it to a service shop for further diagnoses
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. More details .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-bmwz-482-rca-problem-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Clipping means you have exceeded capacity. .A thumbs up would be greatly appreciated if this answer is helpful to you. random-protection-mode-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
check your remote turn on wire that goes between your neg. post and pos. post good should be a 12v wire that hooks to cd player for a turn on and off applcation if you wire direct the amp will not turn off and drain your batter dead or tuggle if you like
Nitro BMW-482... | Answered on May 03, 2014
You have not got your subs wired up poperly, End it fried the ouputs on the amp, Live end learn (Dude)
Nitro BMW-482... | Answered on Nov 12, 2012
http://www.youtube.com/watch?v=B9BJEPPans4&feature=player_detailpage
Nitro BMW-482... | Answered on Apr 15, 2011
left + goes to the amp left - goes to the + on the right sub and the right - goes to the amp try that
rate pls
Nitro BMW-482... | Answered on Aug 18, 2010
it needs repaired, it has an internal short
Nitro BMW-482... | Answered on Jun 09, 2010
have it repaired as previously stated
Nitro BMW-482 Car Audio Amplifier Logo
40 questions posted
Top Nitro Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
matthew walsh
Level 1 Expert
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Nitro Car Audio & Video
Most Popular Question
reset nitro
  • Car Audio & Video
