20 Most Recent
Hamilton Beach BrewStation 47665 Questions & Answers
Reassembly instructions
That little screen that lies at the bottom of the bucket needs to be
snapped out and the washer replaced. You have to unscrew the bottom,
carefully remove the spring loaded lever, ( don't loose the spring)
After fishing the lost rubber washer out of the hole, I used a screw
driver or other similar item to pop the screen out. ( use care not to
poke a hole in screen.) Next replace lever and spring and push the Star
ended piece through the bottom and THEN fasten the washer. Replace all
excess pieces and it should be fixed provided the washer isn't badly
worn. This is the only way I know how to fix it after countless
different web pages and searches.
Need to replace cord
Do you know anyone else who has the same coffee maker as you? borrow it from them and check your wiring from there.
you can get these coffee makers from amazon and wall mart.
I don't have one so cant take a photo for you.
Hopefully someone out there will see this, have one and help out.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
if you remover the cover further and dismantle you should find clues for each wires location.
Hope this helps a bit
Good luck and take care
My 47665 dispenses coffee very
Not a solution, clearing up the problem:
I have this coffee maker, same problem. It is not a problem of needing cleaning. You can hand open the valve at the sink, works find, it is more of an issue of plastic wear, aka the mechanism the cup uses to dispense the coffee. There is a little knob that presses on the reservoir that holds the coffee tank, the problem is there, either the mechanism or the reservoir where it pushes. Clearly a part(s) that needs to be metal, or cheap replacement parts.other than that, very good coffee maker because the holding coffee tank and the coffee/filter are located together. No cooling of the coffee.
It is leaking from where the coffee comes out. I
That little screen that lies at the bottom of the bucket needs to be snapped out and the washer replaced. You have to unscrew the bottom, carefully remove the spring loaded lever, ( don't loose the spring) After fishing the lost rubber washer out of the hole, I used a screw driver or other similar item to pop the screen out. ( use care not to poke a hole in screen.) Next replace lever and spring and push the Star ended piece through the bottom and THEN fasten the washer. Replace all excess pieces and it should be fixed provided the washer isn't badly worn. This is the only way I know how to fix it after countless different web pages and searches.
Coffee grounds are over flowing into my coffee, what's wrong?
This is a very easy simple way to fix coffee grind overflow. I began using another filter on top of the coffee grinds in the basket. This prevents splattering when aggressive brewing or using more than the usual weak coffee measuring, I like mine strong but not bitter. Fixed the splatter and coffee grounds in the dispensing tank. Coffee filters are CHEAP at the dollar store.
