20 Most Recent
Cat5e Cat 5E Modular Plugs - For Round Stranded Cable - RJ45 Mod Plugs (301178) Questions & Answers
Plz explain me exactly for which purpose RJ-45 cable used ?
RJ -45 is a type of connector used on cat5, cat5e....etc cables to connect networked devices...the RJ stands for registered jack but there is really not much you really need to know about it....a RJ 45 JACK is a little bigger than a telephone jack, you'll notice the female type of input on your computer or laptop and the male end will be on the end of the cable that goes into this jack....hope this helps
Cat5e to RJ11
You wont be able to....You need another NIC...you can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Cable stuck
Look at the above left. There should be a plastic lever (with a little nose to hold the plug in) reaching a few millimeters out of the front panel of your hub. Press it to the body of the plug and pull it out. If the lever is broken, use a small screwdriver, a needle or a paper-clip.
hth, Karl
Lag switch
Hey, you are dealing with high frequency - what a strange idea is this? Do you have a 100Mb/s- or 1Gb/s-network? What do you want to achieve?
25m and no signal
Two equipments of the same type - two computers, two routers, two switches - should be connected with a crossover cable.
There is 4 pair cat5E
To use 8 wires cable for 100BaseTX connection only four wires are used, pin 1,2,3 and 6. You can find defective wires by using wirescope which can detect which wire has problems. If these two wires are not one of these I had mentioned according to standards 568A or B (it depends of the rest of the network) then you can use it if not then take care wher to put these bad wires but not on pins 1,2,3 or 6. Take care to document this. The best solution is to replace this bad cable with good one and do everything according to standard procedure.
I need to wire a network cable into a wall plate
I have tried this, and my suggestion is to go back and get the proper wall jack. How much are headaches worth to you? If they are worth more than the wall plate, just **** it up and get the correct one.
I AM BUILDING A NEW HOME AND WAS TOLD THAT CAT 5
I'd go with CAT-6, if your building a new home. While CAT-5 would probably be fine for the near future, CAT-6 has a much higher bandwidth rating, and would be able to pass more data at higher speeds, and would in effect, "future-proof" you home network.
The future is all about high-speed data transmissions, and as more and more things are getting connected to a person's home network (Blu-Ray players, etc.) you're going to be glad that you did...
Everything is getting "smart" these days, there are even internet enabled refrigerators; while not common-place today, who knows what the next 20- to 30-years will bring...
Do it now, or re-do it in the future. The price is a little higher, but thin kabout how much more it will cost you to have the CAT-5 ripped out to be replaced with CAT-6 (or whatever) down the road...
Transfering data from one computer to another
I think there is no way to do
that. You CAN do it, however, with a crossover cable. It looks the same
as a regular cable, but it's not. With the crossover cable, just
connect the two computers and give 'em two IP's in the same network.
Then enable file sharing and it should work. Sorry, I can't go into
much detail because I haven't done that in a looong time, but I think
that's about it. Hope it helps.
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
