20 Most Recent
Jenn-Air JGR8855BDS Gas Kitchen Range Questions & Answers
We were told today that
You are being told the truth. They make 2 versions of Model PRG3010. One is Natural Gas and the other is LP. It had to be done at the factory.
3/20/2011 2:39:24 AM •
Jenn-Air...
Answered
on Mar 20, 2011
F-9 fault code meaning?
Related to door lock, and / or clock issue...
Read this... http://www.fixya.com/support/t5547664-appears_power_off_home
11/13/2010 10:17:17 PM •
Jenn-Air...
Answered
on Nov 13, 2010
Its set up for natural gas is there a kit to make
yes, probably behind unit down at bottom right lookng at back of unit, it is a bunch of orifices in a metal bracket that you have to remove, pull out bottom door and access screws that hold them in there, instructions are in owners manual but dont forget to switch over the regulator and screw back over orfices all the way untill they stop or you''ll get soot in oven
2/9/2010 1:22:37 AM •
Jenn-Air...
Answered
on Feb 09, 2010
Jenn-Air JGR8855BDS Gas to propane conversion
propane is higher pressure than natural gas, there should be some orifices on the stove for the top burners, some have them near the top in a metal clip, some have them in a lower location, usually you can see them from the back of the stove. the oven and broiler may only need "tightened down", and the air blend will probably need adjusting for "flame color", you don't want yellow flame tips, good luck!
3/20/2009 5:18:24 AM •
Jenn-Air...
Answered
on Mar 20, 2009
Oven does not heat up
We may have found it - google Maytag Gas and Electric Range Service Manual (1997 models to present) and save it as a PDF to your desk top. Then print out the PDF pages # 18, 25 & 26, 52, 62 65 & 66. Those pages sound exactly like the problem we're having, which sounds identical to the problem you're having. We now suspect the issue is the gas valve heater coil and the volts it needs for ignition. Because without enough volts, the ignitor won't ignite (like, duh?). The specific PDF page is # 66 in reference to the Glow Bar Operation item # 4. If we're right, we'll need to get three small parts, totaling about $60 in all. Let's hope this is the solution!
1/18/2009 2:49:55 PM •
Jenn-Air...
Answered
on Jan 18, 2009
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
12/19/2008 6:29:43 AM •
Jenn-Air...
Answered
on Dec 19, 2008
