20 Most Recent Jura Capresso CoffeeTeam® (497495) Questions & Answers
Capresso C 3000 order of water lines for dispensers
Unfortunately, without being there in person to inspect the machine and its components, it's difficult for me to provide a definitive answer. However, I can offer some general guidance that may help:
  1. Consult the user manual: The user manual for your Capresso C3000 should have a diagram or schematic showing the different components and their connections. If you still have the manual, check to see if there's a helpful diagram inside.
  2. Look for visual cues: While it can be difficult to identify the tubes by sight alone, there may be visual cues that can help you narrow down which tubes go where. For example, one tube may be thicker or more flexible than the others, or it may have a different color or texture.
  3. Experiment with different configurations: If you're unable to find a diagram or visual cues, you may need to experiment with different configurations until you find the correct one. This can be time-consuming and frustrating, but it may be the only option if you're unable to find any other information.
  4. Seek professional help: If you're still unable to identify the correct tube configuration, you may want to consider seeking professional help. A qualified technician or repair service may be able to identify the correct configuration and get your machine back up and running.
I hope this helps, and I wish you the best of luck in getting your Capresso C3000 back in working order!
2/26/2023 6:08:40 AM • Jura Capresso... • Answered on Feb 26, 2023
I have an Ultima model #121. I haven't used it in a year and tries to this morning. Water comes out the bottom.
The first thing to check is the seating of your water tank. Just a few grains of coffee grounds or dirt underneath the tank are enough to break the watertight seal. Make sure the area under the tank is absolutely clean. That's always worked for me when I've had the leaking problem.
9/2/2017 11:13:06 PM • Jura Capresso... • Answered on Sep 02, 2017
Jura Capresso CoffeeTeam® (497495) Logo
0 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Jura Capresso Coffee Makers & Espresso...
  • Jura Capresso Coffee Makers & Espresso...
Most Popular Question
only coffee out one tube
  • Coffee Makers & Espresso Machines
