20 Most Recent Jura Capresso IMPRESSA Z6 13299 Questions & Answers
Hi, a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Jura Capresso... | Answered on Mar 23, 2015
Hi, I made a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
descale unit as per user book. this will increase steam pressure and thus milk temp.
Jura Capresso... | Answered on Mar 04, 2014
Two to three teaspoonful water overflow after each espresso is normal. That is why the tray is there.
If water collection in the tray is excessive and programmed espresso is smaller, then there is cause for worry.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Jura Capresso... | Answered on Oct 23, 2016
Error 5 is pointing to heating problem. Here are the parts that may be malfunctioning:
1- Thermal sensor not registering heating. Replace it.
2- Heater not heating up. Check continuity on heating element. If there is no continuity, (This is rare). Replace heater (Thermo block).
The problem can be linked to:
1- Missed descaling of machine for extended period.
2- Use of automatic descaling method suggested by Jura. Descale the machine every three months using Manual descaling method.. Services Unlimited Inc Parts Guru Since 1988
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Hi Shoba
Photo sensor or switch is blocked.
Not sure if yours is an Infra Red beam or switch
Clean & inspect with flashlight
Look for light path (blocked) or moveable part (switch)
Actually.... it must use an Infrared Light Emmiter to shine through the grounds holder to the sensor on the other side/
10 Minute Fix.... I hope
Jura Capresso... | Answered on Jun 16, 2015
Jura Capresso IMPRESSA Z6 13299 Logo
8 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Impressa Jura Capresso
  • Impressa Jura Capresso
Most Popular Question
need parts diagram jura impressa z6
  • Coffee Makers & Espresso Machines
