20 Most Recent
Philips (33-01-031) Headphones Questions & Answers
Have no power supply or charger for base unit philips, SBC HC8442/05. Anyone know where to get replacement cheap??
Not all rechargeable batteries will work instead of original batteries. The right battery should have metal body and not, as some batteries, isolated bottom part (-). Such batteries (which will not work) have a isolation ring around bottom connector. Philips has some kind of electronic check if bottom part is connected (integrated with) sides of the battery. So sides and the bottom of the right battery should be a sort of a can. Check the original battery to understand better what I am trying to explain.
5/12/2019 8:16:55 PM •
Philips...
Answered
on May 12, 2019
Philips rechargeable batteries SBC HB550S
Thank you. I have just removed the end label of my Energiser rechargeable batteries & inserted into my Phillips Headphones & they are working just fine.
12/31/2017 3:20:11 AM •
Philips...
Answered
on Dec 31, 2017
Not working
Check if the power signal in the base turns on. If not two things can be appening. The base or it's transformer is damaged, or the output jack of you soundboard is dead. Check the sound form the soundboard with some regular headphones to find the source of the problem.
Make sure that the base and the wireless phones are on the same channel and you batteries are fully charged.
12/26/2014 12:29:00 PM •
Philips...
Answered
on Dec 26, 2014
