20 Most Recent Jenn-Air JDS8850 Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Put the burner base and caps in a resealable plastic bag.
Pour in about 1/4 cup ammonia.
leave in a safe place away from kids and pets.
leave for about 1 to 2 days.
In the sink dump the ammonia.
Wash the parts with water and scrub with green scrub pad.
CAUTION!!! Ammonia is strong stuff. Use gloves goggles and do not breath fumes. Open windows.
Never never never mix with bleach.
Jenn-Air JDS8850... | Answered on Nov 18, 2013
If you can remove the part from the range try this.
If it fits in a large resealable plastic bag do this.
caution, ammonia is strong stuff, sear glover, goggles, do not breathe fumes. Never never never mix with bleach.
Put the part in the bag.
Pour in about 1/4 cup ammonia in the bag.
Seal bag.
Let set in a safe location (outside or locked up away from kids or pets)
Let sit for 24 to 48 hours. Shake the bag a few times so the part is covered in the ammonia. L
Last bring the bag to your sink, dump the ammonia, wash of the part with fresh water. Scrub with green scrubbing pad.
Good luck.
Unplug the range or turn the breaker off for 30 mins. and power the unit back up. If the beeping continues, you will need to replace the clock control. Please post back the results of the power off /on.
Jenn-Air JDS8850... | Answered on Jul 31, 2011
You are basically screwed. Mine went out and Jennair said touch panel was no longer available. Imagine that, just past warranty and can't even purchase the part. I found a new one on ebay and had it replace about 6 months ago. Tonight the stupid think went out again!! Hope you have better luck than we did.
Jenn-Air JDS8850... | Answered on Sep 22, 2010
no.. u must replace the touch pad assrmbly that whole unit.... i think u have a jds9860aab i believe... the part number u would need would be 74005750 it is for sale through sears at $272.00... u might need service.. u can take a look at part at repairclinic.com just type that part number in. ohhh also i believe this is a backordered part so most companies would prob take 2-3 weeks to get soo hope this helps..
Jenn-Air JDS8850... | Answered on Jan 28, 2010
THE NEC NOW REQUIRES YOU TO INSTALL A 4 PRONG PLUG 10-4-WG WIRE CONNECTED TO A 30 AMP DOUBLE POLE BREAKER THE PIG TAIL ON THE NEW STOVE MUST MATCH THE PLUG SO THE ONE OFF OF THE OLD STOVE WILL NOT WORK GET THE 4 PRONG PLUG AS WELL THE WALL PLUG WILL BE EITHER A FLUSH MOUNT OR A SURFACE MOUNT AS TO SAY IN THE WALL OR ON THE BASEBOARD SURFACE REPLACE WITH THE SAME AS YOU HAD BEFORE IT IS LESS TROUBLE IN THE LONG RUN THIS SHOULD ANSWER ALL THE QUESTIONS THE ELECTRICIAN NEEDS TO KNOW IF NOT LET ME KNOW
Jenn-Air JDS8850... | Answered on Dec 23, 2008
if self clean works then sensor igniter did not need changing
sounds like the control was changed to c
top temp is around 550 f or 260 c
check your manual on changing range c to f
Jenn-Air Kitchen... | Answered on Mar 24, 2019
WE CAN NOT AS WE ARE NOT GAS SUPPLIERS HERE AND DO NOT RECOMMEND ANY DIY-ING FOR THEM GAS BLOWS UP WHEN DONE WRONG YOU SEE
Jenn-Air Kitchen... | Answered on Feb 23, 2019
slow lighting is not all that uncommon on these ranges. Make sure the burners are clean and that you can see the spark at each ignitor. If that is OK, check the gas pressure to the burners.
Jenn-Air Kitchen... | Answered on Jan 20, 2019
Jenn-Air JDS8850 Dual Fuel (Electric and Gas) Kitchen Range Logo
24 questions posted
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Kitchen Ranges
Most Popular Question
our jenn air model js9860aab control
  • Kitchen Ranges
