20 Most Recent ASUS Professional 16 Channel H.264 Dvr With 16 X 1/3 Exview Had C Questions & Answers
Asus transformer/tablets blinking power lights; What do the different colors and combos mean?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://homenol.blogspot.com/ https://electronicshelponline.blogspot.com/ If blinks continue without any pause, or the LED light stationery; the main board is faulty. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview'/
8/11/2018 3:51:18 AM • ASUS Televison &... • Answered on Aug 11, 2018
Is ASUS CM-16 compatible with verizon fios
That device has the capacity of about 700 Mbs. The fiber cable wont come all the way into your house. There is a point called Dmark that it stops and changes over to conventional wire. That device will work fine.
12/24/2017 2:59:56 AM • ASUS Televison &... • Answered on Dec 24, 2017
Asus vk266H Hi my monitor (ASUS
The backlight driver could be going bad. The ballast control board most likely is the culprit.
10/30/2017 4:44:53 PM • ASUS Televison &... • Answered on Oct 30, 2017
How do I get rid of grid lines on my Asus computer monitor? I have had it less than one year.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCD panels are given. You can see and compare to that to your device, and can make sure about the fault to an extent.
10/9/2015 10:57:19 AM • ASUS Televison &... • Answered on Oct 09, 2015
Printer spooler not working google cloud print
https://support.google.com/cloudprint/faq/2541828?hl=en
3/23/2015 8:46:45 PM • ASUS Televison &... • Answered on Mar 23, 2015
Motherboard
pc failure?replace PC
4/18/2012 8:24:07 AM • ASUS Televison &... • Answered on Apr 18, 2012
2answers
ASUS adapter for 501J series
You need a mains adapterthat has Input 100-240V Output 19V - 3.24A and the input plug that fits into the power socket of your laptop. It does not need to be from ASUS.
Google search the Internet for a suitable power adapter, make sure the output voltage is the same and the amps is 3.24 or higher.
2/13/2012 6:57:09 AM • ASUS Televison &... • Answered on Feb 13, 2012
Does Asus netbook have wi fi connection? There is
THE NETBOOK MUST HAVE WI FI IN IT. ANYWAY SEND ME THE MODEL NUMBER AND I WILL BE MORE SURE TO HELP YOU.
REGARDS.
PLZ. RATE THIS
7/4/2011 6:08:29 PM • ASUS Televison &... • Answered on Jul 04, 2011
Hi, i got problem with my monitor ,an LG Flatron
I own roughly 50 of the LG L1953TS monitors, and have this exact problem with a high percentage of them. Far higher than any other make/model I've ever purchased.
My only solution was to file a warranty claim with each one.
You might try speaking with LG customer service regarding what has to be a manufacturing defect. I wish you the best of luck with that, as their customer service towards me has not been particularly stellar.
4/15/2011 4:05:30 PM • ASUS Televison &... • Answered on Apr 15, 2011
Codes for aveis tv for remote
My Aveis remote does not have a code on it,in order to for Bell Express to program my remote for the receiver they need to enter the code into their system first,can you help ?
2/10/2011 6:49:44 AM • ASUS Televison &... • Answered on Feb 10, 2011
AC/DC ADAPTER MODEL ADP-90SB BB
http://cheaplaptopsforsale.org/buying-tips/laptop-ac-adapter-not-working-steps-to-resolve-the-problem/
Read the article above. It tells you how to solve this problem.
And if turned out your adapter was defective, the link below may be helpful for you.
http://www.chargerbuy.com/replacement-asus-ac-adapter-19v-4-74a-adp-90sb-bb.html
12/21/2010 4:15:48 AM • ASUS Televison &... • Answered on Dec 21, 2010
ASUS Professional 16 Channel H.264 Dvr With 16 X 1/3 Exview Had C Logo
2 questions posted
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ADMIN Eric
ADMIN Eric
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Televison & Video
Most Popular Question
tcl 55x2us picture freezing netflix
  • Televison & Video
