20 Most Recent FrancisFrancis! X1 - Stainless Steel Espresso Machine Questions & Answers
2answers
FRANCIS Francis espresso problem..just barely coming out..
Try removing the metal grille from the machine. I don't know the term, but it's held in with a single allen screw on the underside of the machine. Don't use the allen key that FrancisFrancis provide, it's made of soft metal and useless. Buy a decent one.
I did this, and found coffee 'goo' a millimetre thick on top of this sheet of metal. Once I'd cleaned it off it was fine. To clean it, I put it into a cup and soaked it with Mr Muscle oven cleaner, left it for an hour, and then scrubbed it clean. I ran a sewing needle across the back to help clear the pinholes.
4/23/2021 2:00:03 AM • FrancisFrancis!... • Answered on Apr 23, 2021
3answers
I have a Francis X1 Trio. Has anyone ever tried to
You need a ground coffee adapter, these are available from various sites online. Do a web search for X1 ground coffee handle and you'll find one. Make sure it's the right one for your machine (check to see if you have the aluminium or brass boiler version)
Just found this site - It's in the UK and I'm not sure if you are but they will probably export to you.
http://tinyurl.com/lhxvg6
Regards
Richard
2/25/2020 2:01:47 PM • FrancisFrancis!... • Answered on Feb 25, 2020
We have had the francis francis for around about 6
I believe the flashing exclamation point means that it requires decalcification. You should be able find the manual for your machine at illy.com.
1/23/2017 8:07:06 AM • FrancisFrancis!... • Answered on Jan 23, 2017
3answers
I am looking for user guide / user manual of the Francis Francis
Go to this site www.redmonkeycoffee.co.uk select expresso machines then FF X1 you will see a link to download manual
2/13/2016 2:32:24 PM • FrancisFrancis!... • Answered on Feb 13, 2016
Illy francis x8 service repair manual
Never found a service manual for a Francis Francis - I took mine apart by looking for bolts.
11/29/2015 3:18:39 PM • FrancisFrancis!... • Answered on Nov 29, 2015
I want to clean the
You need to turn the machine on to perform the flush. What they mean, is to start with a cold machine.
8/13/2015 9:51:43 PM • FrancisFrancis!... • Answered on Aug 13, 2015
When brewing with the X1,
HI
More than likley its your brew head gasket that is leaking. Take off the 4 nuts you hust tighten and it exposes the brew head gasket. Make sure that you put the chrome piece on the same way you took it off. Clean the head good before you put the new gasket on or you could have trouble.
I would check ebay.
8/13/2015 9:45:05 PM • FrancisFrancis!... • Answered on Aug 13, 2015
X1 trio makes huge shots, at the 3rd position it
Hi
The trio is set up for pods. There is nothing wrong with it. The positions on the brew head are for different shots. The 3 rd position lets a lot of water through, and the 2nd one lets less and the first one lets the least water through, and makes the strongest coffee.
8/13/2015 9:41:17 PM • FrancisFrancis!... • Answered on Aug 13, 2015
2answers
Illy manufactured francis francis
brand new x8 wont work
6/3/2015 4:26:41 AM • FrancisFrancis!... • Answered on Jun 03, 2015
I have had the orange Francis Francis X1 for about
If the coffee is good ignore it. It's probably the thermostat element come loose from the boiler.
1/23/2015 12:54:03 AM • FrancisFrancis!... • Answered on Jan 23, 2015
My francis coffe machine needs
Seen them for sale on ebay; also it's a standard O ring so you can get an O ring kit on ebay or Amazon.
1/23/2015 12:53:07 AM • FrancisFrancis!... • Answered on Jan 23, 2015
I'm looking for FrancisFrancis X1 TRIO - Replacement 'O' Ring
I bought an O ring kit on ebay - measure the size of the O ring and get a kit that contains this size. The kit contained 500 O rings for £10 and you'll only use 1.
1/23/2015 12:42:48 AM • FrancisFrancis!... • Answered on Jan 23, 2015
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
168 questions posted
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
FrancisFrancis! Coffee Makers & Espresso...
  • FrancisFrancis! Coffee Makers & Espresso...
Most Popular Question
axis connecting steam knob machine seems
  • Coffee Makers & Espresso Machines
