20 Most Recent
Randell (2030E) Commercial Refrigerator Questions & Answers
I have a custom built
If you were told to replace the entire compressor unit (condensing unit), the person diagnosed the compressor is most likely bad. Depending on the age of the unit, it is hard to tell if this is a good decision. Overall condition plays a role in the decision process as well.
2/10/2018 3:02:43 AM •
Randell...
Answered
on Feb 10, 2018
Russell Hobbs Fridge not working?
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned.
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage.
This refers to water, not juices.
