20 Most Recent
Polaroid Z2300 Instant Print 10mp Digital Camera - White Questions & Answers
Charging battery
If you want to charge your battery within your camera you must plug in the charger cord to the camera while the battery is inside the camera. It is the round cord end that comes with the original camera.
How can I get a user manuel for this camera?
This link will take you to the page .. http://www.manualslib.com/manual/445307/Polaroid-Z2300b.html#manual
A pdf file is also available in Google : go to search and type in -Polaroid Z2300 user manuals .. 1 pdf link should be the one which u r searching for.
https://www.google.co.in/url?sa=t&source=web&rct=j&ei=_DlmVYiKNtGLuASYloGIDg&url=http://www.polaroidstore.com/store/images/pdf/Z2300-polaroid-10-megapixel-instant-print-digital-camera-manual.pdf&ved=0CBwQFjAA&usg=AFQjCNEk0mOwIIKlONixRq-GVZdPgFTQBg
Vertical lines through Polaroid z2300 printed pictures
i have the same issue, my best guess is that because there equally spaced there is something wrong with a cog, i can hear a faint click that is in sync with the lines. i'm going to investagate more so will hopefully i'll have a definative answer soon
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
