20 Most Recent Hoshizaki KM-630M Crescent Cuber Ice Maker Questions & Answers
3answers
Why is my Hoshizaki ice machine evaporator frozen
if the defrost/hot cycle doesn't work, the ice won't fall and eventually freeze everything.
5/7/2017 5:23:06 PM • Hoshizaki... • Answered on May 07, 2017
2answers
Wash Cycle wont kick on
I wish my refrigerator had a wash cycle too- Dude you posted in the wrong section
1/8/2015 4:26:17 AM • Hoshizaki... • Answered on Jan 08, 2015
0answers
My ice maker just have freeze one side
Check the Freon again. Sounds like it is leaking out.
12/24/2011 4:55:43 PM • Hoshizaki... • Answered on Dec 24, 2011
When putting the switch on the comperoser does not
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/17/2011 3:55:21 PM • Hoshizaki... • Answered on Sep 17, 2011
0answers
We have a KM 630 MAH the code that we are
It's programmed into the control board. It is something you do not replace separately. I'd look for what is causing the issue. Probably not a board. Look for water valve leaking water thru. Turn machine off and see if water is still running into the machine. If you have filters, be sure they are clean and you have no less than 20 psi during the fill cycle. Let me know if I can help further
10/12/2010 2:22:48 AM • Hoshizaki... • Answered on Oct 12, 2010
Icemachine is going into harvest
the grate under the evap plates have been known to break off small pieces. These pieces get caught in the discharge of the pump and hold open a spring loaded valve which then let water out and tricks the float into a harvest.
It's the white triangle piece with 3 screws in it usually just about or next to the pump. Look for broken pieces inside of it. Remember, when you take it apart, it's spring loaded.
10/12/2010 2:19:53 AM • Hoshizaki... • Answered on Oct 12, 2010
Km-630mae/where does the L-shaped metal bracket
small bracket does not go inside, but outside the float switch. It goes behind where the float switch mounts. A screw goes thru the float, the bracket, and then into the machine. It holds the float level to it's adjustment.
10/12/2010 2:16:47 AM • Hoshizaki... • Answered on Oct 12, 2010
Just replace the bin switch on a hoshizaki 630mab
according to my wiring diagram, the power goes thru the bin switch and then goes to terminal #10 on the control board, #7 on the control board, and branches off and goes thru the control switch and high pressure switch and then to the transformer.
I would check the "Ice/Wash" switch to be sure it is allowing power thru it. See if you have power at the high pressure switch. If you do, control switch is probably good so that would send me to the transformer. See if primary and secondary power is present.
Let me know if I can be of further help
10/12/2010 2:13:06 AM • Hoshizaki... • Answered on Oct 12, 2010
How to remove the hoshizaki
http://www.hoshizakiamerica.com/manuals/KM-630M_E_serv.pdf
Go to this site. Has manual for several different units with your partial model number.
8/11/2010 3:13:26 AM • Hoshizaki... • Answered on Aug 11, 2010
Machine beeps when turned on ice position
first try resetting the board by pushing the reset button on the board. But make note of the number of the beeps before resetting.
4/27/2010 4:06:04 AM • Hoshizaki... • Answered on Apr 27, 2010
I have a km630mab that doesn't energise the water
check to see that you are getting the proper voltage to the solenoid. If you are, the valve coil is bad and need to replace entire valve. If not, check up stream voltage and determine where you are loosing it.
4/27/2010 4:05:00 AM • Hoshizaki... • Answered on Apr 27, 2010
2answers
Not dropping ice
the water pome geting to hot and not raning
9/4/2008 12:22:03 PM • Hoshizaki... • Answered on Sep 04, 2008
Hoshizaki AM-100BAE ice maker. It has stopped making ice.
After 20 years it will need refrigerant gas and a service. They all lose a little gas via the compressor bearing seal. Parts list http://www.hoshizaki.com/docs/manuals/AM-100BAE_pts.pdf ..
4/6/2024 12:34:07 AM • Hoshizaki... • Answered on Apr 06, 2024
3answers
Hoshizaki 500MAF will not stop making ice
You should Adjust warmer or replace it
6/14/2023 7:12:23 AM • Hoshizaki... • Answered on Jun 14, 2023
Hoshizaki KM-630M Crescent Cuber Ice Maker Logo
Popular Tags
30 questions posted
Top Hoshizaki Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hoshizaki Refrigerators
Most Popular Question
when putting switch comperoser not
  • Refrigerators
