20 Most Recent
McCall DT4-4070 Commercial Refrigerator Questions & Answers
We have a 44020f01c /serial s844119 freezer the
http://www.mccallrefrigeration.com/docs/uploaded/mcl/dmmcseriesireachin%209294297.pdf
The model number has been changed to MCCF-3 download and go to page 18 for the wiring diagram.
This is a dual voltage unit. 220 Volts for compressor 120 Volts for everything else.
I would disconnect the leads to the compressor to isolate it. Then energize the unit and see if It blows.
Using the wiring diagram and a multimeter slowly check each heater, fan light.
We have a McCalls 4070 three door fridge that all
Hello Maureen,
In 20 years the technology changes and reaches its highest available. Instead of repairing the old refrigirator you have buy the new refrigirator.
The new refrigirator available in marlet are highly advanced and more efficient then older one.
You also get the large variety to choose the refrigirator.
Keys
Hi there!
Yes you can order a set from most locksmiths that cut keys to code.
You may be able to order a set by phone for this.
Alternatively, the manufacturer will keep replacements, but may cost slightly more.
I hope this helps you resolve this problem. If it does, Please spare a moment to rate as Fixya! Thanks.
6/16/2008 7:54:36 PM •
McCall...
Answered
on Jun 16, 2008
Where is the defrost timer located in hisense upside down fridge freezer on model NO# HR6BMFF520S
The defrost timer in a Hisense upside-down fridge freezer, model number HR6BMFF520S, is typically located within the control panel or the refrigerator compartment. Here are the general steps to locate it:
- Check the Control Panel: Start by inspecting the control panel of the refrigerator. Look for any knobs, buttons, or switches that control the defrost cycle. The defrost timer may be integrated into this panel.
- Inside the Refrigerator Compartment: If you don't find the defrost timer in the control panel, check inside the refrigerator compartment. It might be located near the temperature control settings or the light fixture. You may need to remove any covers or panels to access it.
- Consult the User Manual: If you're having trouble locating the defrost timer, refer to the user manual that came with your fridge freezer. It often contains detailed diagrams and information about the location of various components, including the defrost timer.
- Contact Hisense Customer Support: If you're still unable to locate the defrost timer, consider reaching out to Hisense customer support for assistance. They can provide specific guidance based on your refrigerator model and help you locate the timer.
Once you've located the defrost timer, you can follow the manufacturer's instructions for troubleshooting or replacing it if necessary.
