20 Most Recent Power Acoustik A1800DB Car Audio Amplifier Questions & Answers
Yes, your amplifier needs the amout of fuses as there are fuse ports.
In case something were to go wrong it would blow the fuses instead of your amp and subs and burning your wire harness up..
I hope this helps.
Power Acoustik... | Answered on May 12, 2013
try checking your speakers and speaker wires for shorts and/or grounds.
Power Acoustik... | Answered on Jan 20, 2011
you could have taken out anything from a protection diode to some switching transistors.
Power Acoustik... | Answered on Dec 06, 2010
One thing to check is to be sure you have a good ground that can sometimes cause similar problems.
Power Acoustik... | Answered on Nov 11, 2010
make sure your remote wire has a good connection, and make sure you have a good ground you might have to scrape a little paint where you ground it out
Power Acoustik... | Answered on Dec 10, 2009
If I don't ask the stupid questions first, I always get burned! Have you tried removing both the +12V and remote connections from the amp and letting it sit for a few minutes? If the amp doesn't automatically reset (and you have removed the condition that caused it in the first place), your amp may need repair, as it might have shorted something internally.
Power Acoustik... | Answered on Mar 12, 2008
Search google for a schematic should be able to find one. I repair amps. Marks Car Audio & Amp repair
e-mail skinnman33 @gmail.com I can be reached at 727-266-6398 Let me know
Power Acoustik... | Answered on Apr 01, 2019
It depends on how many channels are on the Amp. If it's a 2 channel you can bridge it using the positive on one channel and use the negative on the other channel. The Amp will give the sub more power bridging the sub.
Power Acoustik... | Answered on Mar 10, 2019
Power Acoustik A1800DB Car Audio Amplifier Logo
Popular Tags
7 questions posted
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Power Acoustik Car Audio & Video
Most Popular Question
power acoustik a1800db fix protection
  • Car Audio & Video
