20 Most Recent
Sony RDR-HX520 DVD Recorder Questions & Answers
Hi there, My sony rdr hx510 will not open and is
Must used a philip screw driver take out all the screws to the dvd player.Must take the DVD player aparts.Take aparts out the dvd player guard shield to the dvd drive to take out the dvd dic or dics out.Don't push the open button any more,the disc or discs is jamming ur dvd door tray.Will burn out ur disc tray motor,if u keep trying push the open button,trying opening it that way.
I own the sony dvd
if the disc no longer loads on your computer with the data it was suppose to have been written too it may be a finalizing error and you would want to make sure you have all the updated drivers and are using compatible software for it. If after burning the disc it is not being read on other dvd players and is not being read by your own dvd drive on computer or player than it is definitely a hardware problem and will most likely need to be replaced or returned if still under warranty
hope this helps
Robb
What is the type number for sony rdr-hx520 laser pickup unit?
If the DVD asembly is the same as for model RDR-HX510, the part number is 1-797-247-12 and costs: $358.56 with a refund of $145 upon the return of the defective unit. Pricing was from tritronicsinc.com a Sony parts distributor. (I could not find a listing for the HX520 model)
Hope this helps.
Dan
Dvd Recorders
Most DVD recorders have a "Scart" input. I assume your VHS has one also. conect a scart lead form the VHS to "Input" scart on DVD recorder. Select the "scource" of viewing on the DVD to "Scart", press record on the DVD and "Play" on the VHS and away you go. You should be able to view whats happening on your T.V. when you select the scart that the DVD is connected to on it.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
