20 Most Recent
LG RC-197 DVD Recorder/VCR Questions & Answers
Returns error message :Unknown Disc. Please Check
Problem may be reset needed, or lens need cleaning, or dvd recoreder worn out. Reset is pull the plug from the wall for 5 minutes. Turn it back on after reset to load firmware again, may work after that.. TDK makes lens cleaner. LG uses fan so, dirt can get into dvd recorder lens. If the tray moves out wiggly, laser assembly may move wiggly too. Replace dvd recorder which is a dvd+-rw regular ide unit from computers.
How to fransfer video from vcr tapes to dvd
you done that the problem so. press power on bottom & press dvd section mark"open/ close" bottom & hold it untill show in dvd from vcr by lcd screen. if want dvd to vcr. you just playing vcr the system going to vcr section direct. good luck!
I have the same issue of "No Disk" error on LG RC797T DVD Rec.
There are many reasons for the message you receive. Essentially it is a generic message that indicates that the disc inside the unit is unreadable. This can be because the disk is defective, the optics are defective or the spindle motor is defective. There have been cases where I have found the controlling ICs to be defective. The most common cause is a dirty lens on the optics. Cleaning this plastic lens using a cotton swab and alcohol often resolves the problem. This may not be the case here. A good test is to attempt to play a music CD. If the CD plays OK but a DVD does not, it indicates that the controling circuitry and the spindle motor are likely to be OK and that the optics are failing.
Try cleaning the lens and report the results here.
Dan
LG RC-288 disc problem
You need to use CD/DVD lens clening disk. If wont help gently clean the lens with Q-tip and 40% vodka or 50-70% rubbing alcohol
Good Luck
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
