20 Most Recent
kawasaki PVS32801 Portable DVD Player Questions & Answers
Disc not valid messge
yo may want to try cleaning the lens and you might also try cleaning or repairing disc an/or lens
5/28/2020 3:04:35 AM •
kawasaki...
Answered
on May 28, 2020
Dvd will not run
You set has a possible failure of the optical head , which could have gone weak. First of all you need to open the set and look inside the tray that holds the CD. If you notice there is a small eye like lens that sticks around a black module. Use a good cotton swap to gently clean this lens to poilish it with care. Thereafter after cleaning connect the set and put in an original cd that has no scratches. If you have an head cleaner try to use it provided it is of a good quality. If this does not solve, then I sugggest that you will need to replace the optical head. You will have to take out the optical head unit after disassembling the mechanism. Procure the same type spare from an authorised centre. Using a non static soldering irron remove the bridge across the PCB before you install. If you are not familiar seek expert help as an inexperienced work might result in failure of the sensitve device. after fixing the spare , replace all the removed parts carefully. Now you can test. I hope my adivce helps. Good Day
7/8/2010 5:19:24 AM •
kawasaki...
Answered
on Jul 08, 2010
Dvd stops at different spots
Might be dirty or scratched DVD. Have you tried other disks. If they play well, disk is damaged.
Read Ya,
Z
1/2/2010 5:24:31 PM •
kawasaki...
Answered
on Jan 02, 2010
It sticks
You need to isolate the problem. Please try the steps below:
1. Try playing other DVDs to see if that would work.
2. Load the problem DVD into different player to make sure that there's no problem with the disk.
3. Clean the lens of your DVD/R
To clean the lens, you need to buy a DVD cleaner in any computer shop. If same problem exist, you need to contact the computer manufacturer.
Have a great day!
5/11/2009 10:16:36 PM •
kawasaki...
Answered
on May 11, 2009
Disk not valid
hEY SORRY ABOUT YOUR DVD BUT IF YOU CANT FIX IT WILL YOU SELL YOUR REMOTE TO ME?
3/15/2009 1:35:12 AM •
kawasaki...
Answered
on Mar 15, 2009
"Not Valid Disk" message
This Message shows up because it might not be a invalid DVD. Which means the DVD might be scratched, messed up, or sometime when is a DVD that you copied from your computer. Hope it works!
6/17/2008 5:14:33 PM •
kawasaki...
Answered
on Jun 17, 2008
Rechargeabel battery
In Many stores like Walt Mart, there are many "Universal" chargers. Which means you can use one charger for many DVD's.
6/17/2008 5:11:45 PM •
kawasaki...
Answered
on Jun 17, 2008
Scrolling
You can download a manual at this product's official customer support website http://1800customersupport.com/kawasaki, or you can call them at 1-877-252-6873.
8/20/2007 3:38:14 AM •
kawasaki...
Answered
on Aug 20, 2007
