20 Most Recent
Jamo DVD-593 DVD Player Questions & Answers
Door won't open
Usually, the gears either become misaligned, or they will break on you - since they are plastic, this is a common issue. There really isn't much you can do. Even opening it up might not do much for you, as it's very hard to get the gears back into place, or to see what is causing the jam in the first place. If you take it to a service center, they shouldn't charge you much if the gears are out of whack. But if something is broken inside, that's a different story. You'll need to find out what caused the error in the first place.
TWEAK A/V LAB
Need IR code for jamo p404 so that I can use Fire tv remote to control speakers.
Specific IR codes for the Jamo P 404 are not readily available in the public domain. However, you can try the following steps:
Universal Remote Setup:
Put your Fire TV remote into pairing mode (usually by holding down specific buttons).
Follow the instructions in your Fire TV settings to add a new device (in this case, your speakers).
The remote will prompt you to enter an IR code. Since the Jamo P 404's codes are not standard, you may need to try different codes or use the auto-search feature to find a compatible code.
Learn Mode (if supported by your Fire TV remote):
Some remotes have a "learn" function that allows them to learn IR codes from existing remotes.
If your Fire TV remote supports this feature, follow the instructions to teach it the commands from your existing Jamo P 404 remote.
Contact Jamo Support:
Reach out to Jamo customer support or visit their website to inquire about specific IR codes for your model.
They might provide you with the necessary codes or guide you through the setup process.
Remember that compatibility depends on the specific Fire TV remote model you have. If none of the above methods work, consider investing in a universal remote with a broader database of IR codes or explore other options for controlling your speakers.
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
