20 Most Recent
JAKKS Pacific Pokemon Battledome Battle Dome Playset Questions & Answers
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
How do I set time.? No manual, remote does not work.
- Buttons on the Device: Look for any buttons on the device itself. Sometimes, there are buttons that allow you to navigate through menus and adjust settings directly on the device.
- Trial and Error: Try pressing different buttons on the device to see if any of them bring up a menu for setting the time. Look for buttons labeled "Menu," "Setup," "Clock," or similar.
- Long Press: Sometimes, pressing and holding certain buttons on the device can activate different functions. Try pressing and holding various buttons to see if it triggers a menu for setting the time.
- Google Search: If you know the model number of your Ultech device, try searching online for the manual. Many manuals are available for download from manufacturer websites or other online sources.
- Contact Manufacturer: If you're unable to find the manual online or if you're still having trouble setting the time, try reaching out to Ultech's customer support. They may be able to provide you with guidance on how to set the time on your device.
- Replace Remote Batteries: If the remote isn't working, try replacing the batteries. Sometimes, a non-functional remote can be as simple as dead batteries.
2/28/2024 9:57:13 AM •
Watches
Answered
on Feb 28, 2024
Skmei watch 1163- Daylight savings time- how to set
To set the Daylight Savings Time on your SKMEI 1163 watch, first press and hold the "MODE" button for approximately three seconds until the "SET" mode appears. Then, press the "MODE" button again until you reach the "DST" mode. Use the "ALARM ON/OFF" button to toggle between "ON" and "OFF" for Daylight Savings Time. Once you have set your desired option, press the "MODE" button again to confirm and exit the setting mode. Your watch should now display the correct time, accounting for Daylight Savings Time.
2/16/2024 11:07:11 AM •
Watches
Answered
on Feb 16, 2024
Bottom of watch by second hand....what is symbol
You've probably heard people go on and on about the "sweep" or talk about how top quality watches don't make that tell-tale "tick-tock." For all intents and purposes, these people are right. When you pick up a Cartier or Chopard, the tiny hand measuring the passage of seconds glides effortlessly, like a toothless hockey player. In actuality, all wristwatches tick-tock. However, in a true quality watch, the internal mechanism (the movement) is so finely tuned and so well constructed, that these ticks happen as often as nine times a second, producing a flawless sweep. This is the difference between a five-dollar movement and a movement costing hundreds of dollars.
1/28/2024 3:10:21 AM •
Watches
Answered
on Jan 28, 2024
I have a sunbeam 882-1285 and can't set the chimes to match the time of day, need help
I have owned this exact clock for 30 years. Syncing the chimes with the time is very simple.1. Flip the second switch from "Start" to "Set."2. Use the thumbwheel to move the hands to the desired time.3. Use the four "H" and "M" buttons to set the time for the chime. — For example, if the desired time is 12:05, press the first button 1 time, the second button 2 times, skip the third button for 0, and then press the fourth button 5 times. — If the desired time is 9:00, you only need to press the second button 9 times (all unpressed buttons default to 0).4. When you're ready for the clock to begin using the time you've set, flip the switch from "Set" to "Start." That's it! It's that easy.
1/14/2024 7:34:18 PM •
Watches
Answered
on Jan 14, 2024
