20 Most Recent
Mercedes C-Class Exterior Pillar Posts Trim Set Questions & Answers
2001 c320 car starts up and runs but steering wheel is not turning
you can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly
, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
How i fix mecedes c240 esp on and lost power
Ensure the throttle body is clean a sticky throttle valve causes the ESP light to come on , and the vehicle to lose power this is an intermittent failure and is normally experienced just after a fast pull away
Repair for p203d
code p203 d refers to reductant level sensor ---circuit high
or
injector ,cylinder4--signal low===causes for sensor are --wiring --reductant level sensor---ECM
and for cylinder 4 wiring---shorted to ground--injector--ECM you may have to get what a reductant sensor does from a MB service centre and see if it controls the cam advance mechanism
How do i replace rear springs
Hi,you need to take wheele off put the car up on axle stands then there is a tool called a spring compressor,(which are exspensive)or you can do what I did,
I undone the back nut to the lower wishbone put a jack under the wish bone remove the bolt to the wishbone and slowly lower the jack take spring out then replace with new and jack up replace bolt job done,hope this was some help.
C230 mercedes sunroof won't close all the way?
i have a problem with mine if its an old one the motor and mechanisem slows down and some times doesn't close all the way properly you could try cleaning the rubber seals around the out side it may just be sticking as it tries to close properly the rubbers go hard with age and could be making it stick
What is gas gauge fuse called for benz c320.
It won't be fused separately, the gauge will be covered by the dash fuse. If the gas gauge is not moving then check the wiring by tracing the sender unit at the tank. It may be accessed through a small panel in the trunk floor. Pull off the sender wire, ground it on a clean metal surface and with the ignition ON, see if the gauge moves. If it does, then suspect the sender.
Can you open the doors of a 2002 C 240 if the battery is dead
if you have the key, yes, if you have just a key fob (keyless entry) then no because the locks still need power from the car to function. also a "slim-jim" would get it, might throw a security code though when batt is replaced, if you use a coat hanger be sure to place something behind it to not scratch the paint!
