20 Most Recent
Delstar DS-3512 MP3 Player Questions & Answers
Will not play
Check the format of the songs you recently added maybe are not compatible with your device
Lcd screen is busted
get a battery that fits, standard earphones (3,5 mm plug, the small one,)
attach to pc that has usb2.0, copy some mp3's to it, unplug, insert battery, press play and find out!
Disk Error
Try a new high output battery, making sure it is in correctly. Next, try to connect it to your computer and in systems configurations or network highlight your player then click at the top of the menu bar the update driver. Let your computer search the web for a new driver. There should be drivers on your player but they can be damaged by a download from a web site or corrupted from a malfunctioning USB Cable. If you still have the little disc for the USB DRIVER, you can install a new on from it. The disk on your player may need to be wiped clean or all files deleted to restore the player to fuctionality. See if you can downlaod them all to your computer first then try to reinstall the needed driver then upload the music files again. Good luck.
Your player may have experienced a hazard such as a strong magnet at a store, the ones you walk through to leave the store can damage anything you are carryng, including your credit cards. Also, the scanners that the cashier passes your purchase over which reads the numeric UPC or Universal Product Code, if your player came in contact with one or your credit cards, can be affected. It is a good thing to shield your personal data anyway when out in public as the new rip off is to read the electronic chips in credit cards, just by using sensitive equipment that can hear them. A thin layer of aluminum foil inside the lining of new wallets this fall was an attempt to see if this will avert an identity theft/ hacker problem.
Set the Delstar to Randomly play songs
Call Customer Support @ 1-800-998-7771 to get another copy of the manual or ask for their website or google it. Delstar is a company in India. But they have offices here and warehouses and service centers too.Mylittle manual says... Playing Mode (playing the sub-menu) The first item in the playing sub-menu is Playing Mode. When choice is confirmed, the player will play according to the setting rule. SYSTEMS SETTINGS is last on menu as SYS; then...
Replay Mode is the A-B with dual arrows back and forth above the letters on your players menu bar.
Repeat choose one setting when you wish a different playback mode.
[N] = NORMAL Once list song plays, done with. Will continue to play eachsong in the file till through all, then stops. This is the default setting.
[1] = REPEAT ONE Repeat playing one single song.
[D] = with arrow going backwards above it is... FOLDER Plays all the music in the playing folder.
[D] = with dual arrows back and forth above is... REPEAT FOLDER Plays the same file of music repeatedly.
[A] = with dual arrows above is ... REPEAT ALL Repeats playback of all music in the directory.
SHUFFLE
[R] =RANDOM Plays the music in the present folder randomly.
INTRO
[I] = Plays the first 10 seconds of all the music in the present folder in sequence.
My delstar mp3 player model DS3512
The disk you used the first time should still have a copy on file in your computer. Look for AMV Converter; AMV Player; Media Manager; MP3 Player Disk Manager; MP3 Player Upgrade Tool; Uninstall. My little booklet said I didn't need the drivers on the disk but I wanted to know more about the machine than what I could get from the horrible english version of the booklet. I bought the extended warrenty for mine.
Last resort: Click on the UPGRADE TOOL and when you get to the companies website for the download, switch to the: contact us email, if you registered your machine for the warrenty they may let you purchase a replacement disk.
Lcd screen busted
Unfortunately, you are correct. The LCD is broken. There isn't much you can do about it. Time to shop for a new MP3 player.
Will not work
i have one too. i think u hav to wait for a while. this thing kinda ****
