20 Most Recent
Power Acoustik MOFO-15 Car Subwoofer Questions & Answers
Hi i have a power acoustik mofo 15 inch subwoofer
I don't believe they have that option available, probably because everyone would just repair their speakers and not buy more. Depending on how bad the tear is or how much foam is missing, you can buy sealer for it that works fine if you don't mind what it looks like. I have used a thin layer of clear silicone caulk to seal them up before and also used it to seal a hole in the actual speaker itself. You want to use something durable and pretty flexible when doing it, but the possibilities are endless. Hope this helps and good luck!
Speaker not working
before you do that i would recommend seeing if you can send it in under warranty because i know that a lot of speakers when you dissemble them you end up doing more damage then good.
I have 2 15 inch mofos do i need two poweracoustik
You want an amplifier that is rated for the subwoofers. In your case your subwoofers are rated at 1500 watts rms each, so you will need an amplifier of 1500 watts rms or more for one subwoofer. good luck
What size speaker wire do i use with the mofo 15
The size of the wire has more to do with the amp's output than it does with the speakers. The wire should be the same size throughout, from speaker to box, box to amp. A minimum of 16 guage multi-strand wire. Most amps that put out up to 500 watts max or have an RMS rating in the 300 watt range should do fine with this. If you want to be on the safe side, there is no limit to how big your speaker wire can be, only how small or a minimum. If you're using a very high output amp, like over 500 watts RMS, you can use 12 ga. wire. If you want to be on target for your size, I need to know what amp you have and how many speakers you have.
I have no sound to my woofers they were working
Check the fuses on the inline and the amp(s). Then check the power and ground for solid connections and the remote if needed. By process of elimination you should be able to find the fault in the wiring. If all checks on the above the problem would have to lye in the RCA's or speaker wiring. Also be sure to have the proper resistance in your subs (ie.2ohm,4ohm) and that the amp can handle that resistance.
How do i wire two 15 inch subs to 2 ohms
Hello familia_gome,
Those MOFO-15's have dual 1ω voice coils. So the only way you can get 2 of them to present a 2ω load is to use 1 voice coil on each one with the two of them wired in series. Using both voice coils, you can get a 1/4ω load by wiring the voice coils in parallel and then wiring the subs themselves in parallel. You'll get a 1ω load with the voice coils in series and then parallel the subs. Or you'll get a 4ω load with both the voice coils and the subs in series.
Here's a link to Power Acoustik's PDF for the MOFO's. I recommend that you check out the wiring diagrams on page 3.
http://www.poweracoustik.com/SUPPORT/MANUALS/PA-MOFOWoofer.pdf
Hope this helps.
Power Acoustik PD-624B 6.2-Inch Double-Din in-Dash LCD Touchscreen DVD Receiver with Bluetooth. The Radio cannot play any video, gives warning message.
Question edited for a lot more clarity, full make model (what it is)'.
Question moved from Televisions category.
The warning message may have been useful!
People don't realise that factory car audio is operated by and monitored by the Body Control Module (BCM) on a computer network. Your warning chimes and indicator clickers are generated by the BCM and played through the car audio system. The computer has no idea that this new device is!
Take it to an auto electrician or to an Alarm / Audio installer and see if their professional bi-directional grade scan tool computer can reprogram the BCM to ignore your device. Or just put the old one back.
I have a power Acoustik cpaa7dd double den car radio and I keep getting unknown disc errors
- Make sure the disc you are trying to play is compatible with the radio. The radio may not support certain formats or types of discs.
- Check the disc for any visible damage, such as scratches or fingerprints, that may be preventing it from playing properly.
- Check the CD player for any debris or foreign objects that may be preventing the disc from being read properly.
- If you are using an aftermarket CD changer, make sure it is properly connected to the radio and functioning correctly.
My power acoustik pd-620hb won't turn off
POWER/MUTE Button Press it to turn on the unit.Press and hold for 2 seconds to turn the unit off . Press the button briefly to Mute . Please note that the volume will be muted on all audio output connector.
I have a power acoustik pd 701 how do I play videos off my iPhone thru usb cable
- Smart Control enables select Mobile 8 models to communicate with the media player of most Smartphones and tablets
- Smart Control sends playback commands by the AUX cable connected to the headphone output of your smart device
- Control track selection, play/pause, and even answer incoming calls. AUX cable included. Variable Subwoofer Pre-Amp Output
- Play audio, video, and picture files through Mobile 8 from DVD, CD, or 32GB SD/USB flash drive. Supports MP3 & WAV audio files & MP4 video files, and JPG pictures.
- Safely make and receive hands-free phone calls, scroll contacts lists, and stream MP3's via A2DP from your enabled Smartphone. Most Bluetooth enabled Smartphones seamlessly pair
