20 Most Recent Mountain Buggy Urban Single - Red Stroller Questions & Answers
Broken buckle on Urban mountain stoller
might be here
http://myebestbuy.com/allplasticbuckleslist-1.aspx
lots of variants
8/6/2010 6:23:07 AM • Mountain Buggy... • Answered on Aug 06, 2010
Punctured tyre
HI,
I would suggest that you contact your local bicycle shop who will be able to sell you a replacement innertube to repair this.
I hope this helps.
9/22/2009 6:22:19 PM • Mountain Buggy... • Answered on Sep 22, 2009
Urban single 2007 has flat reat tire
You should be able to buy replacment tube at any bike store,if you know what size.
8/18/2009 9:11:33 PM • Mountain Buggy... • Answered on Aug 18, 2009
Urban elite 2006
My urban elite stroller brake seems to tighten, resulting in the extreme difficulty to flip the break up. I noticed that adjusting the wheel further from the axel helps loosen up the brake. I'm wondering though if there is a better fix to this problem.
1/19/2017 6:00:27 AM • Mountain Buggy... • Answered on Jan 19, 2017
How do I tighten the wheel assembly on a 2005-07 Mountain Buggy Urban Jungle Double stroller?
This is a press or pound on type nut usually a one time use! But if you are carefull you can unscrew with a pair of plyers by turning both ways but pulling hard on them! Once you get it off you can put washers on the axle to take up the play. Then before you put the press nut back on make sure you didn't bend up the little pieces of the metal. They should be bairly slanting to the inside of the nut. If they are slanting to the out side bend them in gently. them tap the nut back on!
3/18/2015 8:59:50 PM • Mountain Buggy... • Answered on Mar 18, 2015
0answers
0answers
0answers
The plastic joint that attaches
Not really as its properly attached to prevent it coming off by accident.
Contact them don't disclose about it being bounced about tell them they need to honour the warranty unless they can prove you did damaged it and it just didn't break because of a manufacture problem. But the cost it would take and time to determine what actually failed on it would be too much they would just agree to honour warranty
Don't back down on first phone call keep calling until you get some answers..
9/7/2010 8:37:04 AM • Mountain Buggy... • Answered on Sep 07, 2010
Need conversion set for koala crib 1900R
Need interaction manual for koala baby crib model number 1900R
4/3/2024 11:41:43 AM • Baby Gear • Answered on Apr 03, 2024
I need the 2 solid metal dowels for the drop down rail to ride on
All question need full 'make model (what it is)' as first 3 words. Impossible to guess what this is? Normally if you Google make model parts you will find the items. ..
3/27/2024 5:41:05 PM • Baby Gear • Answered on Mar 27, 2024
Who has good methods to select a good coil spring mattress?
Coil spring mattresses are the best mattresses. They're bouncy plus relives pressure points. Thus, reduce pain and gives a soothe sleep. A person who is deprived of peaceful sleep due to back pain or spine ache can prefer this. I have used coil spring mattress from multiple brands but perfectly satisfied with wakeup's mattress. Click here : https://mywakeup.in/
3/27/2024 2:33:42 PM • Baby Gear • Answered on Mar 27, 2024
Mountain Buggy Urban Single - Red Stroller Logo
5 questions posted
Top Mountain Buggy Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Mountain Buggy Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
  • Mountain Buggy Baby Gear
Most Popular Question
broken buckle urban mountain stoller
  • Baby Gear
