20 Most Recent
Lenovo ThinkCentre A30 PC Desktop Questions & Answers
Keyboard keys working strangely.
you're using the wrong language/ go to control panel then go to languages regional and change everthing to your country or the original country of the laptop
3/5/2009 11:45:32 AM •
Lenovo...
Answered
on Mar 05, 2009
Windows recovert cd
For Lenovo there is a Recover and rescue button just hit that on the startup
For Dell, Hp, Gateway and other big brands
PC Restore or some thing like exist on a hidden partition on your harddrive that contains an exact copy of your computer's original setup.These programs allow you to reset your computer's operating system andsoftware to the original state in which it was shipped to you.
Do the following actions to remove the recovery partition from the hard drive.WARNING: The drive will be reformatted and all user data erased. This action isnot recommended. Be sure to create a set of recovery disks BEFOREperforming this action.Turn on the PC and repeatedly press the F11 key when the HP or Dell or the computer Manufacturer logo appears
then follow the on screen instructions read them and try to to do "Format and reinstall the operating system
Regards
www.MyTechGuru.US
10/21/2008 1:35:00 PM •
Lenovo...
Answered
on Oct 21, 2008
Upgrading the graphics card
You may have to go into the bios and turn the on board video off. Most computers will do it automatically when you add a card. But for some reason yours might not. When the computer first starts up it will say some thing like hit delete to enter setup. some are f10 some are f12 so watch the screen when you start it and it will tell you what key to hit. Then when you are in bios look for the spot where it has your video devise. It should give you the option to boot from agp. I am not that familiar with that card so check to make sure it dose-nt need a power connector plugged into it. It usually will take a floppy drive one or one that looks like a hard drive power plug. Good luck and let me know if it is still not working.
3/1/2008 11:36:56 AM •
Lenovo...
Answered
on Mar 01, 2008
Auto processing
The auto processing is the monitor trying to adjust to a particular resolution. To help you control display quality, please follow the steps given below:
-Open the 'Display Quality troubleshooter' by clicking the Start button, and then clicking 'Control Panel'.
-In the search box, type 'troubleshooter', and then click 'Troubleshooting'.
-In the left pane, click 'View all', and then click 'Display Quality'.
GuruAid.com
3/21/2016 7:05:57 AM •
Lenovo...
Answered
on Mar 21, 2016
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
4/5/2015 9:37:26 PM •
Lenovo...
Answered
on Apr 05, 2015
