20 Most Recent
X-Gaming X-Arcade PC Joystick (XGMPC) Questions & Answers
I have a 1983 popeye
VR353 is a 200k pot that feeds directly in to the vertical oscillation input of the chip on the main board at connection B1. If this pot is broken, you must replace the pot in order to get any vertical oscillation at all.
9/21/2009 9:59:16 PM •
X-Gaming...
Answered
on Sep 21, 2009
Installation
First, I'm going to assume this controller is usb and not wireless, blue-tooth, or gameport.
Second, if you have a usb mouse or keyboard and it works fine, then its going to be that you need to find vista drivers for your device and install the drivers before plugging it in. If you have another usb device, try plugging it into the usb port and if it doesnt work either your computer is faulty or you need to update it.
Vista is rather fickle when it comes to drivers and what not. Instead of windows coming out with the drivers, they let other people come out with them then they endorse those drivers. Try going to logitechs site, they are usually extremely helpful and easy to navigate. You can probably find drivers for your device easily. If you need any more help, let me know, I'll find you a few other solutions.
6/4/2009 2:28:47 PM •
X-Gaming...
Answered
on Jun 04, 2009
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the
disc tray with the label facing up (to the right if the console is
vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will
append all tracks on your current CD to that playlist. Selecting Play
All will clear a current playlist and create a new one consisting of
all the files on the current CD. (Be sure to save your playlist, if
desired, prior to selecting the Play All option.) Files are added to a
playlist in alphabetical order by file name. Playlists start again from
the beginning once the final track has played.
riz.
1/5/2009 11:21:15 PM •
X-Gaming...
Answered
on Jan 05, 2009
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
