20 Most Recent
Samsung UN55ES7100 55" Series 7 LED 3D 1080p HDTV with Smart TV, Clear Questions & Answers
Samsung55in led tv. 7100 series. After a few minutes of being on the picture goes off. But the Samsung power indicator light remains on.
No doubt. Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
11/28/2015 8:23:38 AM •
Samsung...
Answered
on Nov 28, 2015
Jhytu
jhytu aly as fdhg jhtg
Need new watch band for tag heuer watch
TAG HEUER watch bands are costly. Over here in England they cost from £60 to £250 (depends on type, model, e.t.c.), but can rocket sky high if you have one of expensive models.
I would suggest to add a few links to your existing band. This will be cheaper than to buy completely new band.
Visit your nearest watch repair store and ask how to do that. Watchmaker should be able to order extra links and fit them for you.
If you insist on a new band - ask watchmaker to order it and fit to your watch.
Rate me, please.
How do I set time.? No manual, remote does not work.
- Buttons on the Device: Look for any buttons on the device itself. Sometimes, there are buttons that allow you to navigate through menus and adjust settings directly on the device.
- Trial and Error: Try pressing different buttons on the device to see if any of them bring up a menu for setting the time. Look for buttons labeled "Menu," "Setup," "Clock," or similar.
- Long Press: Sometimes, pressing and holding certain buttons on the device can activate different functions. Try pressing and holding various buttons to see if it triggers a menu for setting the time.
- Google Search: If you know the model number of your Ultech device, try searching online for the manual. Many manuals are available for download from manufacturer websites or other online sources.
- Contact Manufacturer: If you're unable to find the manual online or if you're still having trouble setting the time, try reaching out to Ultech's customer support. They may be able to provide you with guidance on how to set the time on your device.
- Replace Remote Batteries: If the remote isn't working, try replacing the batteries. Sometimes, a non-functional remote can be as simple as dead batteries.
2/28/2024 9:57:13 AM •
Watches
Answered
on Feb 28, 2024
