20 Most Recent Casio G-Shock Analog Digital Watch GA-150A-4A GA150A Questions & Answers
Google (casio)(AE 1200 WH)(manual) without parens for instructions.
Casio Watches | Answered on Apr 02, 2019
Press B to switch to the Timekeeping Mode. [SET Hold] will appear and the time offset value will flash. Press B nine times to display the button operation tone setting screen. Selecting [MUTE] causes a mute indicator to light and the buttonoperation tone will not sound.
Button Operation Tone Setting - Other Settings - STB ... - Support - Casio
https://support.casio.com/global/en/wat/ble/stb1000/manual/function/ose_but.html
Videos as well
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&ei=C-abXJn_KsW-jwS4qqSwCQ&q=casio+watch+silence+buttons
Casio Watches | Answered on Mar 27, 2019
Even much older watches that display day and date don't require you to change yourself manually so I can't imagine this would be the case.
If the time part is working okay, bring to the jewellery store, they may have someone there to examine the mechanism. If time not working either, you probably need to wind it or change the battery
Casio Watches | Answered on Mar 21, 2019
It's possible that some part in your watch hasn't been put back (properly) during the replacement procedure of the battery. I'd advise you to go back to the service point and let them check if all the internal part are complete (and in their right position)
Casio Watches | Answered on Mar 16, 2019
If the digital display still works, there is most likely something wrong with the watch movement. If there is no readout at all, the battery is probably dead. In both cases you should take your watch to a service centre to have it checked.
A detailed description of this procedure is found in the manual of your watch. You can find the right manual with the module nr. on the back of your watch (4 digit number in a rectangle)
The manual for your watch can be downloaded via the link provided below:
Timepieces Watches
You need to advance the hours (hour hand) 12 hours forward to have the date changed at 12 o'clock midnight.
Timepieces Watches
Timepieces Watches
Timepieces Watches
Timepieces Watches
The manual for your watch can be downloaded via the link provided below: Timepieces Watches
Timepieces Watches
Casio G-Shock Analog Digital Watch GA-150A-4A GA150A Logo
Popular Tags
13 questions posted
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
set time ga 150a
  • Watches
