20 Most Recent
Acer Aspire E1-571-6650 Laptop Questions & Answers
When i turn the acer laptop on i have an error msg
Well, the computer is telling you that the Windows installation failed to complete because either:
1. The Disk was Damaged
2. The hard drive you're trying to put windows on is damaged
3. Corrupted file
Fix the keyboard on an acer aspire e15
Most laptop keyboards don't fix very well, I am assuming that you have a bad key or two, I always replaced the key board with one from ebay. If you don't think you can do this, then take it to a repair man and it is a relatively easy fix but it is time consuming.
Laptop won't start from on/off.
Yes probably low battery itself. Leave it on charge for an hour or so and then restart it. If it still doesn't solve the problem, then mention it in the comments here. Will try to resolve it.
Cheers.
Bypass starup
This is a very hazardous thing to do. Bypassing the updating can casue a system crash. Still there is a way but I will answer that if you still need to do it.
User manual for acer aspire E1
There are 44 models of the aspire E1. 35 of them have a dvd writer, which will play your dvd's. It is started by the software you use. If you want to burn a disc your burning software withll recgonise the drive. Same with playback software if you are just wanting to watch a movie. I't should have software, or a trial version, of a burning program on it when purchased. Maybe playback software too. You need to review your applications and see what you have and learn what each one does to find it. good luck.
http://us.acer.com/ac/en/US/content/models/laptops/aspiree
