20 Most Recent Streamlight Protac HL Flashlight, 600 Lumens, Pocket Clip, Hi/Low/Stobe, 2-CR123A-88040SL Questions & Answers
How do I use the ten-tap programmable switch
Hi, I have included a link to the instructions for the ten-tap programming.
1/6/2014 7:44:38 PM • Streamlight... • Answered on Jan 06, 2014
How to program the ten-tap" programmable switch.
Hi, I have placed a link to the instructions for the ten-tap programming.
1/6/2014 7:43:14 PM • Streamlight... • Answered on Jan 06, 2014
Don't know how to use the ten-tap programmable switch
The Instructions are here: http://www.streamlight.com/static/document/product_instructions/protac-hl_op_inst.pdf
12/26/2013 10:28:15 AM • Streamlight... • Answered on Dec 26, 2013
What is ten-tap and how does it work
How does ten-tap work?
12/25/2013 2:02:22 AM • Streamlight... • Answered on Dec 25, 2013
What fuse goes in streamlight car charger
find the watts and voltage of the light , watts divided by volts. Example 100 watts divided by 12 volts = 8.4 amps. use a 10 amp fuse.
12/2/2023 7:47:02 PM • Streamlight... • Answered on Dec 02, 2023
HL3 is a streamlight flashlight. I thought you represented streamlight. do you?
https://www.streamlight.com/en/products/detail/index/protac-hl-3
What's your question?
4/24/2019 12:47:40 AM • Streamlight... • Answered on Apr 24, 2019
My Stinger DS HL provided excellent light.....for about the first month. Ever since it has provided less light than my cheapest LED flashlights. Any suggestions on a troubleshooting routine?
This torch has a Proprietary rechargeable nickel-metal hydride batteries (2,200 mAh), that is its made for this torch and nothing else. NiMH like to be kept fully charged and if you discharge the battery too much or leave it discharged it wont charge up fully or at all. All I can sugest is to trickle charge for 12 hours then discharge fully and recharge for 12 hours again, repeat cycle till it lasts longer or replace the battery. A replacement battery will be expensive. I use LED torches with cree led and 18650 Li cells, last much longer than NiMH, easy to replace and cheap.
2/1/2019 1:17:39 AM • Streamlight... • Answered on Feb 01, 2019
Can I change the battery in a Streamlight task light 2AA?
only if it has a charging point and the batteries are rechargeable alkaline batteries are not rechargeable and any attempt to do so will result in an explosion
11/27/2017 1:47:18 AM • Streamlight... • Answered on Nov 27, 2017
Can you help to activate my Roku?
have you connected it to Wi-Fi or ethernet ? Have you connected it to HDMI input of TV ? You need to use the browser in the unit and look up Netflix, Amazon, YouTube for movies to play. does it have a usb port where a wireless keyboard receiver could be plugged in making it much easier than using the remote. I am not familiar with the unit but it most likely is using android like a tablet so find google play store - you need a google email address go to www.gmail.com and set up an email. use it on play store search playstore for movies on line apps
5/3/2014 12:54:40 PM • Streamlight... • Answered on May 03, 2014
0answers
Wont charge
Be the first to answer 4/2/2014 3:37:56 AM • Streamlight... • Posted on Apr 02, 2014Be the first to answer
0answers
Streamlight Protac HL Flashlight, 600 Lumens, Pocket Clip, Hi/Low/Stobe, 2-CR123A-88040SL Logo
6 questions posted
Top Streamlight Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
View Most Popular
  • Streamlight Camping, Backpacking & Hiking
Most Popular Question
dont know use ten tap programmable
  • Camping, Backpacking & Hiking
